Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Supporting Vendors > Pedders USA
Old 06-20-2009, 02:43 PM   #1 (permalink)
Points: 3,666, Level: 1 Points: 3,666, Level: 1 Points: 3,666, Level: 1
Car: 07 Chrysler 300C 3.0L CRD
Member Number: 16841
noise in front sometimes rear
I just had my Pedders installed on my 300C drove from Holland to Norway, my Pedders in front when going over speed bumps or pulling into drive ways sounds to the best I can discribe is the sound of a ruff file scraping back and forth up scape down scrape, the tires are not hitting on flat road they are fine,its embarassing to drive up an sound like an old ford pinto, I've got the LX package with front and rear springs buszhings and steering dampner and struts and shocks. ANy ideas, this keeps up any longer I am going to have to remove them and change brands, I want quiet suspension I did not buy track suspension:
BT ,22Elite,Altezza,HID HL Fogs,KW DNX712 ,2 DVD HR,6 Alpines,amp,sub,StarTech,07-3.0 MB CRD 290BHP-630 N/TQ,R window spoiler,trunk lip spolier,Mesh Grill,vent covers,GB roof,LX Euro pkg,Slim line ,SS pillars,lower rocker,fender trim,300C lighted door sills,StopTech Brakes,K40 radar/diffusers,Paddle shifters,AAC LED 6000K white HL,FL,Pillar 2 gauge tracker sys,Borla,Razor Edge,Remote Start,belly lights,LSD,Pedder,20" w/niko,NTsway bars intercooler,with trans limiter off, VIS SRT hood
orandaberg is offline
Old 06-20-2009, 06:38 PM   #2 (permalink)
I have now narrowed down the noise to the left front strut/spring,someone says it because the spring is not seated correctly or the torgue is wrong, any ideas
Old 06-25-2009, 12:23 AM   #3 (permalink)
dms
Points: 3,491, Level: 1 Points: 3,491, Level: 1 Points: 3,491, Level: 1
dms's Avatar
Car: 2006 Pontiac G/P
Member Number: 16007
Can you give us a picture or 2 of the strut
mike
dms
A
Michael White
Pedders West Coast Manager
mike.white@PeddersUSA.com
925-215-1308
Videos of Stock OEM bushes
dms is offline
Old 06-25-2009, 03:24 PM   #4 (permalink)
This is the result from the mechanic sorry his english is not so good,but he says all is OK now.
Hey pierre
Sorry for the delay,too much work
The bussing for the bære arm was not fittet with greas so esben took them down and lubricated them in.
Good as new.
Lou
Old 06-27-2009, 02:47 PM   #5 (permalink)
Pierre,
The movement that the busses make is very small!!
So don't compare it to a wheel bearing or something like this.
Nothing can happen, as long it is lubricated!
I am sure that the people over-react on a product that isn't theirs.
As i thold before, i don't have any problems to remove the busses as soon you are here.
In the mean time nothing can happen whit a part that makes so little movement.
So just use some lubricant which can be used from the outside and wait till you are here again
Maybe we are having a language situation, But I want to make sure that if they did not put any grease inside the bushing where the center ferrule goes, then just spraying in some lubricant will not work long term.
mike
dms
