2012 Chrysler 300 Emissions Recall M30 - Chrysler 300C Forum: 300C & SRT8 Forums
Performance General Discussion Discussion about performance enhancing modifications. Please select the appropriate sub-forum performance classifications.
post #1 of 3 (permalink) Old 10-11-2012, 01:52 PM Thread Starter
Chrysler Customer Service Agent
Points: 6,352, Level: 1 Points: 6,352, Level: 1 Points: 6,352, Level: 1
ChryslerCares's Avatar
2012 (LD) Dodge Charger
2012 (LX) Chrysler 300
NOTE: This recall applies only to the above vehicles equipped with an 8 speed automatic transmission (sales code DFG).
The Powertrain Control Module (PCM) and Transmission Control Module (TCM) on about 66,530 vehicles may have been inadvertently programmed with software that may permanently set an internal temperature too high diagnostic code or not run the position valve stuck diagnostics. The internal temperature too high diagnostic fault can cause permanent Malfunction Indicator Lamp (MIL) illumination. Failure to run the position valve diagnostics can allow an improperly operating position valve to go undetected and fail to illuminate the Malfunction Indicator Lamp (MIL) as required by regulation.
The PCM and TCM must be reprogrammed (flashed).
Repair Time = Approx 25 min
ChryslerCares is online now
The Following User Says Thank You to ChryslerCares For This Useful Post:
MADDOG (10-11-2012)
post #2 of 3 (permalink) Old 10-23-2012, 09:26 AM
Points: 4,573, Level: 1 Points: 4,573, Level: 1 Points: 4,573, Level: 1
AlfredMay's Avatar
Car: 2012 Chrysler 300 Ltd
I just received my notice of recall for this on 10/22/12. Made an appointment for Monday at the dealer. This is for the M30 recall which is different from some other 8 speed trans recalls.
AlfredMay is offline
post #3 of 3 (permalink) Old 11-01-2013, 10:25 PM
Points: 33, Level: 1 Points: 33, Level: 1 Points: 33, Level: 1
Car: 2012 Chrysler 300 Limited
I had the M30 recall done on my German-made ZF 8-speed a week ago. It took about 30 minutes. Flashing the TPM & PCM changed - improved - the shift between 1st and 2nd. It shifts smoother.
Randy_K is offline
RECALL: Fuse - 2011-2012 Dodge Charger & Chrysler 300 Rambit Technical Service Bulletins / Recalls 4 05-20-2012 10:56 AM
2012 GENESIS R-SPEC compared to the 2012 CHRYSLER 300c SRT8 Normgarry 1st Gen SRT8-Specific General Discussion 23 02-24-2012 12:52 PM
2012 CLS vs. Chrysler 2012 SRT8? Normgarry 1st Gen SRT8-Specific General Discussion 42 07-25-2011 10:08 PM
Chrysler need's to recall this! Big Bob Problems / Dealer Service 15 09-19-2005 06:41 PM
emissions recall Krock43 Problems / Dealer Service 1 11-23-2004 06:12 PM
