To Tune or NOT to Tune..... - Page 5 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Performance Forums > Performance General Discussion
Performance General Discussion Discussion about performance enhancing modifications. Please select the appropriate sub-forum performance classifications.
Old 12-15-2012, 05:08 PM   #41 (permalink)
Points: 8,978, Level: 1 Points: 8,978, Level: 1 Points: 8,978, Level: 1
Activity: 19% Activity: 19% Activity: 19%
CPT_SRTOCHO's Avatar
Car: 2007 chrysler 300SRT
Member Number: 37530
Originally Posted by Fisch View Post
Good to hear. So what was the problem? The user?
Well, what type of driving are you looking for?
The tune that I use the most for everyday driving is a 93 octane CAI / firmed shifts / throttle booster at about 15% / lowered fans at 185 and 195 / adjusted tire size for my summer tires / speed limiter set for summer or winter tires / auto upshift cancel
Will all those settings work With the 91cai tune???
Sent from my SPH-D710 using AutoGuide.Com Free App
CPT_SRTOCHO is offline
Old 12-15-2012, 05:20 PM   #42 (permalink)
Points: 7,599, Level: 1 Points: 7,599, Level: 1 Points: 7,599, Level: 1
cwhite2005's Avatar
Car: 05 Chrysler 300C
Member Number: 40950
Nooooo!!
No idea what your talking about???
Yes... It was the user.
Since I already had a problem and had to send it in I had already had myself convinced that it wasn't gonna work.
It was the user...
Sent from my Samsung Galaxy 2
cwhite2005 is online now
Old 12-15-2012, 05:26 PM   #43 (permalink)
cwhite2005's Avatar
Well... 93 octane is not readily available here. I'm sure it's somewhere around but not to close to me. 91 is pretty much all over so that's why I chose that tune.
As far as my driving.. Not to aggressive.. But still want to have fun.
I definitely want firmer shifts.
What is the throttle setting on it?
I can't really adjust the fan settings yet.
I have winter tires on now so no need to set that.
Just curious on some suggestions.
Old 12-15-2012, 09:26 PM   #44 (permalink)
Points: 52,208, Level: 1 Points: 52,208, Level: 1 Points: 52,208, Level: 1
Activity: 82% Activity: 82% Activity: 82%
Fisch's Avatar
Member Number: 22401
Those are just parameter adjustments. I assumed you would have the same parameter options regardless of 91 or 93 tune - maybe I'm wrong. I haven't tuned 91 since I first tried it after I bought it. Like 93 so much more that I've never turned back.
Originally Posted by cwhite2005 View Post
Nooooo!!
It was the user...
Hahahaaaaaaaaaa.
Don't overthink this Chad. Just tweak it and have fun. Find the settings you like. Just stay away from the more advanced settings (spark, etc) unless you know what you are doing. But all of the push-button style parameters are safe to play with. Even with a challenged user.
I believe both firmed shifts and the throttle booster are under "transmission". Throttle booster is more of a butt dyno tweak, but I like it. It basically shortens your gas pedal. So when you are at 50% throttle physically, it actually is sending a signal of 60% or something for example. Just makes her feel a bit more jumpy.
Go ahead... tweak and test... tweak and test...
Fisch is offline
Old 12-15-2012, 09:35 PM   #45 (permalink)
cwhite2005's Avatar
Hahahaaaaaaaaaa.
Ok... But another question that comes to mind is can I delete certain parameters changes or do I have to start over completely by reinstalling the stock?
I will say this.. After I did the tune I took it out for a "test".
Crazy! It's been raining here all day so the pavement was wet so traction was a problem so with that being said... Approximately how long will the tires spin before loosing power to the wheels because of the ESP?
My old car, Chevy Cavalier Z24 had the same option.. Traction control. Almost instantly the power would be gone to the wheels when they broke traction by the traction control kicking in. Sucked!
Unfortunately that's all I can compare to and obviously it's not much to compare to.
I guess I will find out when the snow flies here.
Old 12-15-2012, 09:41 PM   #46 (permalink)
Fisch's Avatar
You don't have to go back to stock - you have the option to modify the current tune that's installed. However, I don't think you get the full list of options, so you might need to just reload the 91 tune and select the parameters from scratch depending on what you are tweaking... but you don't have to reload the stock, then reload the tune, etc.
You can "turn off" the ESP with the stock button on the dash or with the InTune under "traction control", but you really need to add a NoESP mod to truly turn off all of the traction. But even without a NoESP mod, the tires will spin for quite awhile without losing power if you hold it right. The esp really interrupts the party if you start to float laterally I've noticed.
But again, add a switch to your ESP line and don't worry about it ever again. Flip the switch and let loose to your heart's content!
Fisch is offline
Old 12-15-2012, 09:45 PM   #47 (permalink)
cwhite2005's Avatar
I am definitely doing what you suggested for the noesp mod. No question there.
Right now I am just getting through Christmas with my girls then it's back to play time for myself!
Old 12-15-2012, 09:51 PM   #48 (permalink)
Fisch's Avatar
I hear ya.
But remember, all you need is a $2 switch, two wires, and about an hour... and then play time really begins. Happy to help when you are ready to go for it.
Fisch is offline
Old 12-27-2012, 01:55 PM   #49 (permalink)
cwhite2005's Avatar
To all you "tuner" experienced guys. I will be taking my car on about a 4000 mile trip in March. What tune would be the best? I think I saw an mpg tune or something like that. Anyone familiar with that tune? What is that tune exactly?
Since I will be traveling I won't know where the 91 will be available.
Maybe the stock tune would be my best bet?
Thoughts?
Old 12-27-2012, 03:24 PM   #50 (permalink)
Major Contributing Member
Points: 10,753, Level: 1 Points: 10,753, Level: 1 Points: 10,753, Level: 1
onesickhotrod's Avatar
Member Number: 22985
Send a message via AIM to onesickhotrod
Thoughts?
Depends how fast you need to get there lol...
mpg tune would be best as long as the tune is 89 or lower octane rating as unless you have mapquest show what octane is available you may not have 91 or higher available.
Sent from my DROID2 GLOBAL using AutoGuide.Com Free App
ONESICKHOTROD
2005 modified 300C
Rochester, New York
Visit my garage for details
onesickhotrod is offline
Need help. Diablo tune or custom tune for srt8 (Moved) nvmy300c SRT8-Specific Performance & Engine/Intake/Exhaust Mods 12 11-08-2011 11:33 PM
Should I uninstall the Diablo tune before getting a tune-up/sparkplugs at dealer? CraigTroll Tuning/CMR/Dyno/DataLogging/Gauges 4 06-06-2010 06:32 AM
Moved: ***Everything you wanted to know about a full CMR tune and a WOT handheld Tune*** Trojan Tuning/CMR/Dyno/DataLogging/Gauges 20 01-28-2010 06:04 PM
Fuel mixture with altitude question-Predator 91 tune and CAI tune dylzsrt SRT8-Specific Performance & Engine/Intake/Exhaust Mods 5 11-26-2009 06:12 AM
Diablo Can tune vs. custom tune dtpracing SRT8-Specific Performance & Engine/Intake/Exhaust Mods 22 11-09-2007 06:28 PM
