Just got my intune and jet tstat, any advice on tunes or mods??? - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Performance Forums > Performance General Discussion
Performance General Discussion Discussion about performance enhancing modifications. Please select the appropriate sub-forum performance classifications.
Old 01-25-2013, 05:17 PM   #1 (permalink)
Points: 4,601, Level: 1 Points: 4,601, Level: 1 Points: 4,601, Level: 1
Joe79692's Avatar
Car: 2005 Chrysler 300c
Member Number: 38241
I finally got it I'm really excited to see what it can do for my C and see what all the hype is about tuning wit the intune, can anyone tell me what they've thought about the results and if they modded any of the tunes
Sent from AutoGuide.com App
Joe79692 is offline
Old 01-25-2013, 06:34 PM   #2 (permalink)
Points: 28,856, Level: 1 Points: 28,856, Level: 1 Points: 28,856, Level: 1
MADDOG's Avatar
Member Number: 11602
For now, I suggest ya install one of the tunes available on the unit and go with that. Modifying the tune can be done after a bit of reading on how to do that. For instance, if you install the T-Stat, then you'll want to change the fan settings. Same thing goes for changing tire and wheel sizes if you ever go that route.
Custom tunes are not done by you. That comes on a dyno with a trainer tuner.
Just put on the tune and go enjoy yourself for a bit. Remember, if you select a particular tune that requires 91 octane fuel and all you have in the car now is 89, don't run it too hard until you can fill up with 91 or better octane.
Michael
MADDOG is online now
Old 01-25-2013, 06:43 PM   #3 (permalink)
Joe79692's Avatar
What up maddog, yea I wanted to install the tstat and get the tune for that and also my aftermarket CAI but ill just wait on that and ill see if can find out how to do those mods and yea I wanna do the 91 octane but I do have like half a tank of 89 so ill let it go down and ill put the time for 91 then ill full it up wit 91 what do u think???
Joe79692 is offline
Old 01-25-2013, 06:57 PM   #4 (permalink)
MADDOG's Avatar
The tune for the tstat install is not a separate tune. We just need to get into the installed tune and change the fan settings.
You have to put a tune on the car first in order to be able to modify the tune so go ahead...install the 91 tune now, fill it up with 91 and go for it.
You can play now if ya want. Just don't really hammer it until ya get a full tank of 91.
The CAI and fan setting stuff can be done later.
Old 01-25-2013, 07:26 PM   #5 (permalink)
Joe79692's Avatar
Ok I get what ya mean so should I wait on the tstat fan setting or do I do it now???
Joe79692 is offline
Old 01-28-2013, 01:16 PM   #6 (permalink)
Joe79692's Avatar
Hey maddog on the fans do I just bring them down to 180 for on and off fan settings???
Joe79692 is offline
Old 01-28-2013, 01:20 PM   #7 (permalink)
MADDOG's Avatar
That's a bit too low. Even with a 180 degree tstat the fans will run all the time and wear out pretty fast.
I have my LS fans set for 191 and my HS fans set for 199; all conditions. Those settings assume you have the 180 degree thermostat installed. Don't change the fan settings if you haven installed the thermostat.
Old 01-28-2013, 01:25 PM   #8 (permalink)
Joe79692's Avatar
Ok sounds good ill try that I changed the tstat an of course the anti freeze come out, when I put the 180 tstat and covered it and added more anti freeze but my car is really jumpy would it be because the anti freeze come out when I opened it and put the new 180 tstat???
Joe79692 is offline
Old 01-28-2013, 01:50 PM   #9 (permalink)
Joe79692's Avatar
Is that normal for my car to have an rough idle after I switched the tstat???
Joe79692 is offline
Old 01-28-2013, 01:55 PM   #10 (permalink)
Points: 20,251, Level: 1 Points: 20,251, Level: 1 Points: 20,251, Level: 1
Sodak's Avatar
Car: 2006 Chrysler 300c SRT8
Member Number: 24540
No should run normal, did a sensor come unpluged in your intake?
See My Garage
http://www.300cforums.com/forums/garage/1129
SRT A Factory Hotrod
Sodak is online now
180 tstat advice bama1 Engine Cooling 35 09-09-2012 12:24 PM
advice on upcoming mods Collins_Motorsport Appearance General Discussion 1 12-27-2010 05:08 PM
looking for advice on mods i6q SRT8-Specific Performance & Engine/Intake/Exhaust Mods 8 08-19-2008 03:37 PM
Help & Advice on some exterior mods Nordy Appearance General Discussion 11 02-15-2007 01:15 PM
PERFORMANCE MODs - Need advice... CMYSRT8 SRT8-Specific General Discussion 33 04-25-2006 06:30 PM
