B&G Flashes - An alternative to a tuner - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Performance Forums > Performance General Discussion
Performance General Discussion Discussion about performance enhancing modifications. Please select the appropriate sub-forum performance classifications.
Old 10-05-2006, 03:44 PM   #1 (permalink)
Elite Contributing Member
Points: 42,897, Level: 1 Points: 42,897, Level: 1 Points: 42,897, Level: 1
Meister's Avatar
Member Number: 942
Ported Power Performance/B&G Flashes - An alternative to a tuner
Dave Kasper up in Michigan has been causing quite a stir on other forums with his flash of one's ECM to increase performance and enhance driveability.
We're fortunate to have one of own as a supporting vendor for this fine performance product. XCITSNU, Jeremy Stein, owner of Ported Power Performance, can not only make the process of owning a B&G-flashed ECM much easier for you, he'll save you money in the process. That's a true win - win proposition.
Here is Jeremy's contact info:
Jeremy Steinman
POWER PORTED PERFORMANCE
http://www.300cforums.com/forums/pow...rformance.html
performance@powerported.com
859-816-1824
Contact him and he'll make things happen. Jeremy can help with any number of performance enhancing mods, including heads and cams.
If you would, post up your questions and comments here, and we can all work together at getting educated about this alternative to a superchips tuner (about the same price as one, and going higher, depending on your needs). I expect that Jeremy will be doing most of the heavy lifting with regard to answering your questions and getting you hooked up with one.
Here are some existing URLs from our neigbors over at LX forums. A review here will answer many of your questions:
Existing threads:
1. B&G PCM REFLASHES - Buy Price Special for the month of Sept 2006: http://www.lxforums.com/board/showth...537#post529537
2. 5.7 B&G Flash - Style 2 now ready - Special Pricing through Oct. 06: http://www.lxforums.com/board/showthread.php?t=41857
3. MFO5 UPDATE: B&G v2 Flash & HEAT Stage 1 Cam added: http://www.lxforums.com/board/showthread.php?t=41926
4. Does B&G Flash really work?: http://www.lxforums.com/board/showthread.php?t=39798
5. b&g flashes,do they work?here is our results http://www.lxforums.com/board/showthread.php?t=38151
PPP Meister Warrior cam-#01
GSM 1000 hp halfshafts-#01
SRT8 instrumentation-#01
Goodyear F1 GS-D3s-#01
Shock tower braces-#01
MotoRad 176° tstat-#01
DR Stage 2 heads-#02
SRT8 Brembos-#01
GSM 5.7L Mod-#01
Fast56K-TCM-#01
AirHammer-#01
12.97@107.7-#01
176 mph-#01
Willow: 1:44-#01
Laguna: 1:45-#01
12.3/113.8/1.74
Last edited by Meister; 10-05-2006 at 10:39 PM. Reason: Facilitate the process of acquiring one...
Meister is offline
Old 10-05-2006, 04:04 PM   #2 (permalink)
Points: 4,913, Level: 1 Points: 4,913, Level: 1 Points: 4,913, Level: 1
JimmyBamSlam's Avatar
Car: 2006 Dodge Magnum RT
Member Number: 7791
Sure here's one......Do these tuner chips accomodate 89 octane for the 5.7L? And what kind of performance(Hp/Trq) can I expect on a stock car?
2006 Magnum RT
MODS:
-Factory SRT8 Air intake
-Corsa cat-back
-5-point harness Baby seat
2005 Smart fortwo Cabrio
MODS: E.A.T chip
That's right, 62 tire rippin horses and 75 asskickin ft/lbs of torque giving 70mpg!
JimmyBamSlam is offline
Old 10-05-2006, 04:14 PM   #3 (permalink)
Points: 21,786, Level: 1 Points: 21,786, Level: 1 Points: 21,786, Level: 1
crhemi's Avatar
Car: 2006 Chrysler 300C SRT
Member Number: 3307
What if you have to take your car in for warrenty work?
Can you lose the flash or have it discovered by the dealer?
crhemi is offline
Old 10-05-2006, 04:42 PM   #4 (permalink)
Meister's Avatar
Member Number: 942
Bill, it's for that reason that I purchased a new ECM online - some have done so through their dealer if they had a good rapport with them. I sent the new spare in for the flash, not my primary ECM. It's a 3-minute job, 5 tops, to swap the ECMs out. I would simply swap the stock ECM back in for the dealer visit.
Not sure about A, Jimmy, but I'd strongly suspect a Yes answer. (I've invited EXITSNU, supporting vendor who sells the B&G flash, to this thread. Hopefully he'll fill in here.)
As for B, that has been the $64 dollar question. All so far who are using the flash are at least partially modded up. Next week at the Mods Face OFF, MFO5 in Sacramento (do a word search here and also over at LXForums.com for MFO5), a stock LX Hemi may be tested with the B&G flash. I haven't heard final details on that one.
Originally Posted by FreebirdSRT
(From another thread) Jim. Let's talk about the B&G Stage II and the SRT motor.
With Long tube headers, high-flow cats and cat back plus a CAI. Would the stage II help out with the parts I have added. I know the flash will open 1st gear 100% instead of 75% OEM.
Would like to know your thoughts. Thanks my friend.
Yes, Dave can pretty well dial for what you have there, Mark. I know that Bo seems quite pleased with his B&G flash. He'd be a great resource for specifics for you.
Originally Posted by Midnightsun300c
Thanks for the B&G feed back. I may just hold of for a little bit based on your experience and the fact that GSM won't cover their chip for the supercharger with the PCM flashed or with the Jet Stage II installed. I think GSM's main worry is interference with their chips fuel delivery.
We are kind of in the same boat because there doesn't seem to be a specific flash available that takes advantage of the ported heads and performance cam we have. Did you not want the B&G flash to change the shift point or did they not have that ability?
B&G only flashes the ECM. Changing the tranny shift points requires flashing the TCM as well.
Last edited by Meister; 10-06-2006 at 01:58 PM. Reason: Add Freebird's and Midnightsun300c's questions
Meister is offline
Old 10-05-2006, 08:42 PM   #5 (permalink)
Points: 1,385, Level: 1 Points: 1,385, Level: 1 Points: 1,385, Level: 1
Car: 2006 Chryler 300C SRT8
Member Number: 5724
Will post before and after dynos pulls Sunday afternoon. This car is modded up a bit. But have final put some milage on the B&G flashed ECM. I do have a customer with a stock SRT8 that has a B&G II in for about 200 miles, we will be dynoing that one next Fri and will post before & after dynos also. Both car run and drive great, very good performance accross the board. Clean idles, great accelleration, clean full power shifts, and more RPM.
A special thanks to:
Jeremy Steinman
859-816-1824
Jeremy is great to work with, quick to get your needs answered & orders filled. He is a class act and
dedicated to performance enhancements we are all looking. Myself and my customers thank Jeremy for the help and products he has been able to supply. An untold amount of effort and work has gone into his offerings of such great products for other 5.7 & 6.1 engines and management sustems. Give him a call and let him answer your questions, I'll take the quess work out of your performace search.
Dave in fla
FIXER is offline
Old 10-06-2006, 08:58 AM   #6 (permalink)
Points: 6,130, Level: 1 Points: 6,130, Level: 1 Points: 6,130, Level: 1
Car: 2008 smart car Black passion coupe
Member Number: 2914
Meister, great write up. I ordered my spare ECU on Tuesday and will send it to Jeremy at PPP as soon as I get it, which should be today. Fixer, couldn't agree with you more. In the few communications I've had with Jeremy, the guy is top notch! Can't wait to get this B&G flash in and join the party.
Doyle is offline
Old 10-06-2006, 01:40 PM   #7 (permalink)
Points: 20,327, Level: 1 Points: 20,327, Level: 1 Points: 20,327, Level: 1
Car: 99-06 Ford Mustang Cobra, 700HP Vespa, Range Rover, future SRT-8
Member Number: 6435
Jeremy's a great guy and a loyal customer of ours. I say give him a ring if you're looking for more HP.
StealthAuto is offline
Old 10-06-2006, 08:46 PM   #8 (permalink)
Points: 21,663, Level: 1 Points: 21,663, Level: 1 Points: 21,663, Level: 1
GEN XER's Avatar
Member Number: 600
Sounds like a winner if it works.
DARKSIDE - 31OCT06:
SOLD 1 SEP 09
GEN XER is offline
Old 10-06-2006, 10:23 PM   #9 (permalink)
Points: 2,676, Level: 1 Points: 2,676, Level: 1 Points: 2,676, Level: 1
khaleal's Avatar
Car: 2006 Chrysler 300C SRT8 Silver Steel
Member Number: 4643
is a test flash on the SRT8 ecm in the works?? looking for something other than a jet chip to bring this beast out.
More pics @ khaleal on car domain
khaleal is offline
Old 10-08-2006, 10:49 AM   #10 (permalink)
Member Number: 5724
The B&G Flash is already availble, Jeremy has suppied us with the II stage for one of my customers and we made an additional 31hp and 40lb torque. WE just dyno the car this morning @ 8:30. COntact TYPE0149 for the news. I let him tell all now.
Contact Jeremy @ Power Port Performance for any other information, he is a Supporting Vendor on this site and a great guy to work with.
FIXER is offline
Aftermarket Satellite Stereo & Stock Sirius Tuner Wick333 Car Audio/Alarms/UConnect/Navigation 0 02-22-2010 09:04 AM
Xenon flashes Whiteman Appearance General Discussion 0 11-10-2007 03:27 AM
B&G Flashes On Sale! tbyrne SRT8-Specific Performance & Engine/Intake/Exhaust Mods 1 06-18-2007 08:55 AM
B&G Flashes On Sale! tbyrne Tuning/CMR/Dyno/DataLogging/Gauges 3 06-14-2007 08:31 AM
Diffrence in B&G Flashes Elton SRT8-Specific Performance & Engine/Intake/Exhaust Mods 1 02-22-2007 01:11 PM
