C vs challenger - Chrysler 300C Forum: 300C & SRT8 Forums
Performance General Discussion Discussion about performance enhancing modifications. Please select the appropriate sub-forum performance classifications.
post #1 of 17 (permalink) Old 02-15-2010, 11:43 AM Thread Starter
Points: 5,000, Level: 1 Points: 5,000, Level: 1 Points: 5,000, Level: 1
05HEMI-C's Avatar
Car: 2005 chrysler 300C
C vs challenger
stock for stock how bad dose a 5.7 challenger beat the 5.7 C?
05HEMI-C is offline
post #2 of 17 (permalink) Old 02-15-2010, 11:56 AM
Major Contributing Member
Points: 33,170, Level: 1 Points: 33,170, Level: 1 Points: 33,170, Level: 1
xiaolong's Avatar
Car: 2007 Chrysler 300C SRT8
well the 5.7 Challenger has 370hp and 390tq vs the 5.7 in the 300 with 340hp?
c will lose. the cars weigh nearly the same, but suspension on the Challenger and the added power will put it ahead
edit: it will probably put some lengths on a C at XXX speeds
CMR Custom Tune by Xtreme Horsepower
Resonator Delete
AirHammer CAI
185 Tstat
406hp, 420tq (on occasion)
The SRT8 is gone, but not forgotten.....
Now: 1992 SC300-2JZ-GTE swap, 72MM turbo, E85 and more....
xiaolong is offline
post #3 of 17 (permalink) Old 02-15-2010, 12:06 PM
Points: 8,037, Level: 1 Points: 8,037, Level: 1 Points: 8,037, Level: 1
300fisch's Avatar
Car: 2006 & 2008 Chrysler 300C & 300C SRT8
The new 5.7L for the 300's put out more 360hp and 390 lb-ft torque. I think it was changed in 2009. I'm thinking it would be fairly close since Dodge states the Challenger R/T gets up to 60 in 6 seconds, which is around the same as the revised C's.
300fisch is offline
post #4 of 17 (permalink) Old 02-15-2010, 12:30 PM
xiaolong's Avatar
ok i wasnt sure when the power upgrade was coming in..
should be much closer, if the Chally is a 6-speed and the driver is competent, it should pull more
xiaolong is offline
post #5 of 17 (permalink) Old 02-15-2010, 12:31 PM
Points: 8,273, Level: 1 Points: 8,273, Level: 1 Points: 8,273, Level: 1
robaustin's Avatar
C has 10 less horsepower and weighs slightly more. Also, with a shorter wheel base, the challenger may get a little more weight transfer onto the rear wheels on launch for a minor traction advantage.
Magnesium Pearl
T-Rex custom grill
22Elite Console Cover & door elbow pads
Edashkit Real California Walnut Kit
BT catch can & pink thingy replacement
Hotchkis Sway Bars
Diablo Predator CAI + 91 tune
no name CAI, similar to Air Hammer
MotoRad 4127 Thermostat
BFG's 245/55/18 on Magnum rims
robaustin is offline
post #6 of 17 (permalink) Old 02-15-2010, 12:33 PM
xiaolong's Avatar
sounding more and more like a drivers race....especially from a dig, if the C gets a good start
on a roll, i say the Chally slowly pulls, be interesting to see!!
but vs an older C, Chally will pull well
xiaolong is offline
post #7 of 17 (permalink) Old 02-15-2010, 01:35 PM
300fisch's Avatar
I do think the Challenger has an advantage in any case, especially if there were corners and curves involved the C would definitely loose.
300fisch is offline
post #8 of 17 (permalink) Old 02-15-2010, 02:52 PM
Points: 1,063, Level: 1 Points: 1,063, Level: 1 Points: 1,063, Level: 1
hemis&harleys's Avatar
Not quite the matchup asked for
My wife has the 08 R/T charger w/CIA and Predator, with our local LX club at the 1/8 and 1/4 mile tracks last year, she never lost to a 08 R/T Challenger auto or 6 speed and she faced the 5 or 6 different challengers in our group multiple times. Our R/T is the basic package and is about 150 LB's lighter than the Daytonas and she weighs less than 100 lB's and that is some of it,
I cannot ever remember the Automatic Challengers starting to pull back on the big end. The six speeds with the 3.73 Track-Pac could not get any traction out of the hole but would be really coming on on the big end but could never quite catch her.
The R/T's best run is 1/8- 8.79 1/4-13.89
Karl
2008 Chally SRT8
1994 Blazer w/383 stroker
2007 Softail Custom w/103 SE
hemis&harleys is offline
post #9 of 17 (permalink) Old 02-15-2010, 04:04 PM
robaustin's Avatar
Explain. Challenger RT, Charger RT and 300C are basically the same car and have the same suspension more or less. Shorter wheel base in the Challenger might benefit in an autocross course with tight turns but on a road course with the same rubber, it would be a driver's race.
post #10 of 17 (permalink) Old 02-15-2010, 04:24 PM
300fisch's Avatar
I was more referring to the shorter wheel base. I think the ride in a Challenger is slightly tighter with less roll then 300's. I'm not sure if the suspension is different in a Challenger I just assumed it was.
300fisch is offline
Re the Challenger, does anyone know... Ken Lally Other Chrysler/Dodge/Jeep/Fiat Vehicle Discussion 18 03-04-2008 09:53 PM
Challenger Fabes General Discussion 22 09-28-2007 05:13 PM
Challenger on TV Hogan 1st Gen SRT8-Specific General Discussion 0 02-02-2006 08:25 PM
