Old 11-29-2005, 09:13 PM   #1 (permalink)
Member Number: 2476
Is this how the Airaid Intake is suppose to work?
Ok, i just got my Airaid from Wycoff (Came a day earlier) and after using it, im a little happy and dissappointed.
First off, the installation was like 10 minutes and very easy.
Now, when i tested it, it sounded funny.
Ok, the only time I hear the deep tone is when im between 3000 and 4000 RPM's. Once I pass 4000 RPM's, it sounds like a stock air filter, it goes completely silent.
Is that the case with all the intakes, or is something worng with mine?
NautcaSprt6 is offline
Old 11-29-2005, 11:23 PM   #2 (permalink)
urbanchemist's Avatar
Car: 2007 Jeep Grand Cherokee SRT8
Member Number: 350
Send a message via MSN to urbanchemist
i have the mopar cai and you can hear it from the time you put you foot on the gas and it only gets meaner sounding as the engine gets into the higher rpm's. i am not famaliar with that airaid system.
2005 SATIN JADE C(TRADED IN)
2007 JEEP GRAND CHEROKEE SRT8
urbanchemist is offline
Old 11-30-2005, 04:00 PM   #3 (permalink)
ILLNOIZE's Avatar
Car: 2005 300 C
Member Number: 3714
Send a message via Yahoo to ILLNOIZE
i did this one and i like it alot and sounds good
www.roarfilter.com
LAS VEGAS SUN BURN
05 300C
cool vanil
22''crusier alloys
tinted windows
roar intake
2000 dodge intrepid , 2005 chrysler 300c & the 06 chrysler 300 the wifes car
ILLNOIZE is online now
Old 11-30-2005, 05:35 PM   #4 (permalink)
JustForFun's Avatar
Member Number: 1361
NautcaSprt6,
Should growl all the way through the powerband. Sounds to me like you might have a leak. Make sure all of the connections are "tight".
JFF
JustForFun is offline
Old 11-30-2005, 10:35 PM   #5 (permalink)
II kings 9:20's Avatar
Car: 2005 Hemi 300C
Member Number: 132
JFF Hit it I think, my Volant got meaner the more you put your foot in it and it was very progressive. Try a search for the Airaid, I know a few members have them, if you locate one try a PM to see what thier experience is if no one with this intake chimes in.
II kings 9:20 is offline
Old 11-30-2005, 11:21 PM   #6 (permalink)
StarJack's Avatar
Member Number: 2201
Should growl in proportion with the throttle postion as far as I know, mine does. Something is wrong me thinks. Does the engine act at all starved for air over 4k rpm? Wondering if something is pulling closed over the main intake pathway...
2005 Cool Vanilla 300C loaded, Painted Mud Guards, Mopar Cold Air Intake, 35% Carbon Tint, Mopar Remote Start, Visor Graphics, Custom Engine Shroud, Diablo Teardrops, Borla Catback, K-40, Roof Wing, False Firewall, Ultimate Pedals.
StarJack is offline
Old 12-02-2005, 08:17 AM   #7 (permalink)
Member Number: 1323
I have the Airraid intake and I hear the growl anytime I accelerate.. Once I am cruising at a normal speed, 70- 75 it tends to quite down.. The need for more air is not needed and in turn normal aspiration.. Sounds like I know what I am talking about hugh.. It just sounded right.. I still do have my air silencer on, if that makes a difference.. I am also running the Borla System
dsg049c is offline
Old 12-02-2005, 08:33 AM   #8 (permalink)
Member Number: 2476
I have an idea, but dont know if it will work.
What if I left the Airaid system on, but changed the air filter to a Mopar or Volant cone shape.
Would that work?
You think that would make a difference.
Maybe there is a defect on the Airaid Air Filter.
Old 12-02-2005, 10:42 AM   #9 (permalink)
Member Number: 1323
The only difference between the Airraid and the other systems is the actual intake tube.. Airraid uses the factory accordion tube and of course the other systems use a straight through intake tube, in turn the air flows through clean which in turn gives you more air faster.. Now it depends on how much horse power you have and the demands of your engine if you can use all of the extra air and what kind of gains you are getting by the extra CFM's.. Is the cost worth the extra 1 or 2 lost HP claimed? Without out the programming you are not able to fine tune it anyway.. Just my 2 cents..
dsg049c is offline
Old 12-02-2005, 01:35 PM   #10 (permalink)
5point7's Avatar
Car: 05 yes! 300C
Member Number: 533
Did you remove the factory silencer? If not, then yank it immediately and you will notice much more sound.
It comes out easy, but you have to take it out from beneath the car. Will take another 20 minutes...
SOLD 2005 Silver C...Life goes on.
5point7 is offline
