Old 09-05-2006, 02:40 PM   #1 (permalink)
Haywood's Avatar
Car: 2008 BMW 135i Coupe
Member Number: 5640
Help!! Fan install for GSM Mod
Guys,
Does anyone have better install pictures of where the "green wire" is located than the GSM instructions? I feel like any idiot because I can't find it. Installed the ABS wires easily, but can't find the where you splice into the fan wires. Thanks
Haywood
Former SRT-8 Owner
2008 BMW 135i Coupe
Haywood is offline
Old 09-05-2006, 10:08 PM   #2 (permalink)
Midnightsun300c's Avatar
Car: 2006 Chrysler 300c AWD
Member Number: 6238
Originally Posted by Haywood
Guys,
The picture quality of my fan/torque mod sucked too. Try this link http://www.300cforums.com/forums/239185-post129.html. It will get you connected to other links if those pictures don't help. Good luck.
Midnightsun300c is offline
Old 09-06-2006, 12:34 PM   #3 (permalink)
Haywood's Avatar
Member Number: 5640
Thanks for the reply, but I'm alittle confused. This shows that you are connecting a wire into the fuse box. The instructions don't described that.
Haywood is offline
Old 09-06-2006, 01:09 PM   #4 (permalink)
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (18)
someone else had a similar issue here:
HELP! with GS ESP/Fan Mod Install
Mr. iNCREDIBLE is offline
Old 09-06-2006, 01:10 PM   #5 (permalink)
crhemi's Avatar
Car: 2006 Chrysler 300C SRT
Member Number: 3307
Thats the Jim Turner mod not GSM
crhemi is offline
Old 09-06-2006, 04:55 PM   #6 (permalink)
Member Number: 3745
Actually, that is someone else's mod. My instructions are given below in my sig.
From what I have seen with the GSM mod, they are actually cutting wiring and inserting the relay in the wiring at the splice point. I have seen the installation, but have not seen their instructions.
I think the green wire MAY be on the wiring harness on the fan shroud itself.
jimt
Cool Vanilla 2006 300C Build 09-05
Predator! CAI 93 tweaked with more fuel / Airaid CAI
Custom FanMod (The one that I use) / Custom FanMod (Simple Version)
Hotchkis Swaybars / SRT8 Suspension
Magnaflow CatBack (customized by MF)
JimTurner is offline
Old 09-07-2006, 09:49 PM   #7 (permalink)
Member Number: 6238
Sorry I didn't see you post sooner...you've probably already finished by now. I am not sure how much help I could have been on this one anyway if that link was of no help as I have a lowly 5.7. On my GSM fan mod I did have to tap into the fuse box ( power tap supplied) and in addition I needed to splice (crimp splice supplied) into the wiring bundle below that feeds the fuse box. I do know that the pictures were poor quality and of little help. I looked on the GSM web page hoping to find some better pictures and instructions for the AWD but had no luck. I hope everything turned out OK. I sure like mine now that it is installed.
Old 09-08-2006, 07:45 AM   #8 (permalink)
Haywood's Avatar
Member Number: 5640
jimt
Very detailed instructions! You should call GSM and have you write their instructions! Still haven't found the green wire. GSM did call me back, but I was out of town. I'll get it done this weekend.
Haywood is offline
Old 09-12-2006, 11:01 AM   #9 (permalink)
Haywood's Avatar
Member Number: 5640
Still Need Help!!
Guys,
I need someone who has a build date of 2-06 or later to help me install the fan mod wire. I don't have the fan relay like others and GSM is just as confused. Thanks.
Haywood is offline
Old 09-12-2006, 12:39 PM   #10 (permalink)
crhemi's Avatar
Member Number: 3307
Oops!
jimt
Jim,
Thanks for the correction and sorry for the mis-information... all this modding is getting jumbled up in my memory banks lol!
crhemi is offline
