Old 09-09-2006, 09:47 AM   #1 (permalink)
Member Number: 5741
Who manufactures the stock 203 deg thermostat?
I compared the stock thermsotat (5.7L engine) with a prestone and
the latter looks "cheap" in comparison. There must be a reason why the
stock thermostat (dia 63mm, 203 deg) is more complicated.
WHo makes it? I would like to go to a lower temperature with the same
thermostat design,
Thanks,
Gert
2000ssnb is offline
Old 09-09-2006, 10:22 AM   #2 (permalink)
crhemi's Avatar
Car: 2006 Chrysler 300C SRT
Member Number: 3307
I bet Meister would know.
crhemi is offline
Old 09-09-2006, 01:02 PM   #3 (permalink)
Meister's Avatar
Member Number: 942
Thank you, Bill, but I'm not sure who makes the stock tstat. It's a high quality tstat, with a great flow rate, but lacks the fail-safe feature of our preferred Robert Shaw 383-170.
PPP Meister Warrior cam-#01
GSM 1000 hp halfshafts-#01
SRT8 instrumentation-#01
Goodyear F1 GS-D3s-#01
Shock tower braces-#01
MotoRad 176° tstat-#01
DR Stage 2 heads-#02
SRT8 Brembos-#01
GSM 5.7L Mod-#01
Fast56K-TCM-#01
AirHammer-#01
12.97@107.7-#01
176 mph-#01
Willow: 1:44-#01
Laguna: 1:45-#01
12.3/113.8/1.74
Meister is offline
Old 09-09-2006, 04:34 PM   #4 (permalink)
Member Number: 5741
Is this Robert Shaw 383-170 a 180 deg thermostat? That's what I would like to go with or is there a 383-180?
Gert
2000ssnb is offline
Old 09-09-2006, 06:02 PM   #5 (permalink)
crhemi's Avatar
Member Number: 3307
Gert
I believe it's a 170 and I'd like to know also if they make a 180...Jim...Jim
crhemi is offline
Old 09-09-2006, 06:08 PM   #6 (permalink)
65standard's Avatar
Car: 2006 Dodge Magnum R/T
Member Number: 6662
milodon makes a really nice high flow thermostat in a 160* or 180*
part numbers #16405 and #16406
worlds fastest N/A magnum R/T
65standard is offline
Old 09-10-2006, 08:06 PM   #7 (permalink)
Meister's Avatar
Member Number: 942
It *is* a nominal 170, Bill, but actually runs at a near-perfect 176 degrees (with a fan mod or a cool day on the open road). Otherwise it will run just as warm as the stock 203.
I recommend it highly, 2000ssnb. It's the only failsafe tstat out there for the LX Hemi that we've found to date. You can read more about it in post #1 here: Alternate thermostats for the LX Hemis
Meister is offline
Old 09-12-2006, 11:22 AM   #8 (permalink)
Member Number: 5741
Meister,
thanks for the feedback. I googled Robert-Shaw etc. but nothing relevant
came up - where can you buy this one and under what name?
Gert
2000ssnb is offline
Old 09-12-2006, 11:50 AM   #9 (permalink)
Meister's Avatar
Member Number: 942
...thanks for the feedback. I googled Robert-Shaw etc. but nothing relevant
Gert...
Check post #1 here for all the info you need to evaluate, purchase and install the Robert Shaw failsafe tstat: Alternate thermostats for the LX Hemis
Meister is offline
