Old 09-19-2006, 09:26 AM   #1 (permalink)
JimmyBamSlam
JimmyBamSlam's Avatar
Car: 2006 Dodge Magnum RT
Member Number: 7791
6.1 headers on a 5.7?
Hey does anyone know if the factory srt8 headers are compatible with the 5.7LX? I'm aware of the oxygen sensors being in different positions, but is that the only pitfall?
Also, if they are compatible, what if any hrspwr gains can I expect?
2006 Magnum RT
MODS:
-Factory SRT8 Air intake
-Corsa cat-back
-5-point harness Baby seat
2005 Smart fortwo Cabrio
MODS: E.A.T chip
That's right, 62 tire rippin horses and 75 asskickin ft/lbs of torque giving 70mpg!
JimmyBamSlam is offline
Old 09-19-2006, 10:51 AM   #2 (permalink)
Hemi31
Hemi31's Avatar
Car: 2006 dodge SRT8
Member Number: 8105
I believe the port sizes are larger on the 6.1 headers and they won't seal properly to the 5.7 heads.If your looking for an inexpensive shortie the JBA's will get you good gaind for around $450.I ran them on my 5.7 and picked up a good 2 tenths.
Hemi31 is offline
Old 09-19-2006, 05:12 PM   #3 (permalink)
JimmyBamSlam
Member Number: 7791
Did you use them with the stock exhaust? And did you notice any noticable drone?
Old 09-19-2006, 06:46 PM   #4 (permalink)
392STU
392STU's Avatar
Car: 68 Dodge Charger
Member Number: 6205
The 6.1 port is a "D" shape port and the 5.7 is more rectangular and narrower. I haven't tried it but I think there is enough meat to make them match with a die grinder. The stock 6.1 manifold (really a headar) is a really nice part. It even has an antireversion lip about 3/4" past the flanges. It would be a very expensive part from the aftermarket.
392STU is offline
Old 09-19-2006, 07:26 PM   #5 (permalink)
Hemi31
Hemi31's Avatar
Member Number: 8105
I used them with a Borla 112 and High flow cats and there was no drone and was quiet till you stomped on the gas.
The stock SRT manifolds will not work with the stock cats either as they are longer than the 5.7 manifolds and have different o2 sensor locations.
Hemi31 is offline
Old 09-20-2006, 06:53 AM   #6 (permalink)
JimmyBamSlam
Member Number: 7791
Thanx for the insight. much appreciated!
Old 09-20-2006, 06:55 AM   #7 (permalink)
JimmyBamSlam
Member Number: 7791
Pardon my apparent ingnorance, but what is an antireversion lip and what does it do?
Old 09-20-2006, 11:56 AM   #8 (permalink)
392STU
392STU's Avatar
Member Number: 6205
It is a lip just inside the flange that facing so it does not effect exiting gasses but will act as resistance to back flow through the exhaust. I helps reduce cammieness and helps low rpm driving
392STU is offline
