Old 11-05-2006, 07:06 PM   #1 (permalink)
Points: 2,425, Level: 1 Points: 2,425, Level: 1 Points: 2,425, Level: 1
Car: 2006 chrysler 300c srt8
Member Number: 5174
GSM Problems (formerly 'Thank you GSmotorsports')
I just finished installing my s/c on my 300c srt8 and all i can say is wow she pulls twice as hard as she did. It is amazing to see this four door car fly the way she does. Corvettes and Cobras look out. I am going to no problem raceway wednesday night so i will be posting results when i get home. once again thanks GSmotorsports
LA srt8 is offline
Old 11-05-2006, 07:57 PM   #2 (permalink)
Points: 2,249, Level: 1 Points: 2,249, Level: 1 Points: 2,249, Level: 1
Husker's Avatar
Car: 2006 Chrysler 300 SRT8
Member Number: 8326
tick, tick, tick
Red Inferno Magnum SXT-sold
Red Inferno Magnum R/T- sold
Silver 2006 300C SRT8
Options I,II SunRoof and Side Curtain Airbags
I just LOVE the LX platform!!!!
Wife's
05 Garnet Chevy Suburban Z71
Husker is offline
Old 11-05-2006, 08:07 PM   #3 (permalink)
srt8danno's Avatar
Member Number: 1971
Congratulations on your install. I sincerely hope you’re car achieves what you want it to achieve without mishap. We have read several instances in which the motor didn’t survive this mod…..do you have concerns? Best wishes and good luck killing those Vettes and Cobras!
srt8danno is offline
Old 11-05-2006, 08:12 PM   #4 (permalink)
Points: 3,256, Level: 1 Points: 3,256, Level: 1 Points: 3,256, Level: 1
PimpJi's Avatar
Member Number: 8846
crazzzzyyyyyy
PimpJi is offline
Old 11-05-2006, 08:59 PM   #5 (permalink)
Member Number: 5174
I have read all the bad but i have read alot of good. i am just running the stock setting for now until we pull the motor and bulletproof the bottom end then we will see some real #'s and real boost.
srt8danno there is always concern but how boring would life be if we never modded everyone would run the same and we would have to stay home with wifes and girlfriends instead of hanging with the guys at the shop and at the track.
LA srt8 is offline
Old 11-05-2006, 09:04 PM   #6 (permalink)
Points: 3,637, Level: 1 Points: 3,637, Level: 1 Points: 3,637, Level: 1
Midnightsun300c's Avatar
Car: 2006 Chrysler 300c AWD
Member Number: 6238
LA srt8...Congrats. What AFR are you running with the "stock" setting? Did you do the install yourself?
275/40/20 Pirelli P Zero Rosso tires; Detata Double D 20x9 chrome wheels; KW VII coilovers; Dynatech LT Headers; CORSA Exhaust; 180 Tstat; DR Heads; FRI Littleboy Cam; 6.1 forged crank & dampener; RR forged 8.6:1 pistons; forged rods; A Pillar PSI & AFR meter; Bullet twin screw w/ intercooler; 15 psi w/ 90 octane; Methanol Injection; Predator; Tuned by Underground Performance.
Midnightsun300c is offline
Old 11-05-2006, 09:06 PM   #7 (permalink)
Points: 3,840, Level: 1 Points: 3,840, Level: 1 Points: 3,840, Level: 1
Sleeper300's Avatar
Car: 2006 SRT8 Silver C
Member Number: 3867
quest for power...
Good luck on your quest for power, yet there are some options left unknown. did you get a base kit or the big boost kit. .
The kit makes good power, yet doesn't even come close to what they claim it can make, since tuning isn't even close to being figured out and my buddy has the Fastest SRT8 on DR's in the country 11.51 @ 122 My car only went 12.37 @ 115 on street tires.
Take good notes and keep an eye on your plugs, since all the engines i'm aware of that have lost cylinders would have been found early with more frequent plug checks.
Enjoy with caution. P.s. check your plug shank lenths, are your stock plugs longer than the plugs in your kit? I'll bet unless they changed something that they aren't even colder ranges. that's what i found in mine, threads left exposed to combustion and a stock range plug, worse case senario that should have blown more engines than they have.
Sleeper300 is offline
Old 11-05-2006, 09:17 PM   #8 (permalink)
Member Number: 5174
i have not played with the settings. The instructions said that the fuel management box had it burned in it. I finished my install this morning so i have not been able to call gs motorsports and ask them some ?'s whoever has the 11.51 srt what other mods does he have?
p.s. someone help us with tuning please
LA srt8 is offline
Old 11-05-2006, 09:22 PM   #9 (permalink)
Points: 5,042, Level: 1 Points: 5,042, Level: 1 Points: 5,042, Level: 1
Car: 2006 Chrysler 300C SRT-8
Member Number: 3518
Udluuz ran a 11.51 @ 122.48 at Sacramento Raceway
Hal
2006 300C Black SRT8
426 purpose built for Twin Screw
505/506 NA
623/650 150 shot on a 91 octane tune
HalV48 is offline
Old 11-05-2006, 09:42 PM   #10 (permalink)
Husker's Avatar
Member Number: 8326
In all honesty, good luck I really hope it works for you! Just please keep an eye on the plugs, mainly the front 1-3 cyclinders..seems the majority of the burnt pistons were from the front due to the way the stock manifold dist air...
Husker is offline
