Old 12-26-2006, 09:10 PM   #1 (permalink)
tbyrne
Car: 2006 . SRT-8
Member Number: 601
B&G Programming Available At TBYRNE Motorsports!
B&G has been seeing some very impressive results from their tuning plus we've been getting alot of requests from customers so it is time to add this to our performance listing!
Using 8/16/32 bit emulators, remapping software, device programmers, EGT probes & Wide band 02s, to customize your vehicle's performance. Then using a combination of in-house software, in-depth experience of engine management software, and processor manipulation the maps of interest are identified. B&G uses their serial data stream reader and real-time emulator via software to rewrite the map contents to achieve the required results. Checksum calculations are performed to ensure reliability and free of any Check Engine Lights.
B&G SRT 8 2005/2006 300C/Magnum/Charger/Jeep (NGC)
This PCM upgrade is designed for Off-Road and Race use only, This PCM upgrade is for stock or modified vehicles see details below
Stage I $449.99
Revised premium 91 oct fuel (MBT) timing & WOT Fuel tables
Stock rev limit (6275)
Idle speed raised to 750
Modified stall air/fuel torque management, Modified stall timing torque management
Stage II $649.99 (most popular 6.1 flash!)
Revised premium 91-93 oct fuel (MBT) timing & WOT fuel tables
Rev limit raised to 6450 or 6800
Firmer Shifts
No stall air/fuel torque management, no stall timing torque management, modified shift torque management, WOT allowed at stall in 1st gear.
(The stage II flash has Produced 30HP gains & 40 Ft Lbs torque as A/B tested @ DC Performance on a Dyno Jet with a stock 06 LX SRT8 Vehicle). Your results may vary. B&G does not guarantee these numbers and uses these numbers as 3rd party reference only, as numbers will and may vary between Dynos and Dyno Shops.
3.5 and 5.7 owners can also share in the fun!
05-06 Dodge/Chrysler Passenger Car with 5.7 Hemi - $449.99 -
This PCM upgrade is designed for stock vehicles or vehicles with some modifications (mild cam, cold air, headers)
05/06 Hemi 300/300C/ Magnum/Magnum R/T/Charger/Charger Daytona Premium fuel & (MBT) timing curves, 750 idle, 6500 rev, 140 mph, cooler fan on temp
BG3.5 - B&G 3.5L Passenger Car Flash - $449.99 -
05/06 3.5L V-6 300/Charger/Magnum Premium fuel & (MBT) timing curves, 7000 rev limit, cooler fan on temp, 140 mph limit, modified torque management
This programming is much more aggressive than what would be seen with a handheld programmer so you'll see better performance gains. It can also be customized to go along with other modifications. You won't have to worry about what to do with the computer after installing an aftermarket set of heads and/or a camshaft later!
This tuning is listed on our website. You can place your order their or by giving us a call at 1-877-482-9763.
Have a good day!
TBYRNE Performance LLC
Fall River, MA - 1-877-482-9763
www.tbyrneperformance.com
tbyrne is online now
