Old 05-11-2007, 03:34 PM   #1 (permalink)
followme2DQ's Avatar
Car: 2007 chrysler 300csrt8
Member Number: 11932
nitrous grade
i think the difference between the nitrous the speed shop fills your bottle with and medical grade nitrous is that sulfer is added. so by running medical grade you will not see performance gains, however i have the ability to get medical grade for about 2 bucks a lbs , whereas the speed shop is gettin just about 5 bucks a lb. can i run the medical grade in my zex system with out a problem?
thanks travis
2007 300csrt8 bb
followme2DQ is offline
Old 05-11-2007, 08:54 PM   #2 (permalink)
NorCalSRT-8's Avatar
Car: 2006 SRT-8 300C
Member Number: 3016
Send a message via AIM to NorCalSRT-8
As far as I know you can run the medical grade. I was talking to a guy out at the local dragstrip that was running medical grade nitrous in his 8 second Camaro.
THE WORLD'S FIRST LX TO NEED A ROLL CAGE!
NorCalSRT-8 is offline
Old 05-11-2007, 10:14 PM   #3 (permalink)
Hyprspec's Avatar
Car: 2006 Chrysler C SRT
Member Number: 2892
Send a message via AIM to Hyprspec
Only difference I'm aware of is, medical grade won't kill you if you inhale too much of it. haha, I'm sure it will be fine, fill er up and give it a shot see how it works.
486rwhp/560wtq
Hyprspec is offline
Old 05-12-2007, 12:43 AM   #4 (permalink)
Moose's Avatar
Car: 2006 SRT-8 6.1 Hemi 300c
Member Number: 4390
Trader Rating: (4)
The nitrous you buy at the high performance shop is the exact same as the medical. The only difference is there is a chemical added to the non medical stuff that will make you very sick before you can get high off of it.
This: Automotive nitrous available to the public often has trace amounts of sulphuric compounds added to prevent recreational use. The sulphur additives only act to make the taste and odor of the gas unpleasant, and does not diminish the effects of the gas in any manner (although some sulfur compounds may be harmful to the lungs when inhaled, elemental sulfur is non-toxic)[citation needed].
Taken from this: Nitrous oxide - Wikipedia, the free encyclopedia
Moose Burnout here
Highest trap 120 MPH
Fastest reaction time 0.00
Mod list:
Secret Moose Diablo tune
Magnaflow high flow cats
TNT dual nozzle
Corsa cat back
GSM fan mod
180 tstat
Back to Back Calendar Winner
Moose is offline
Old 05-12-2007, 05:31 AM   #5 (permalink)
thanks so much, but hmmm now i am thinkin i need to re-run the purge lines, so they end up in the car
