Old 05-11-2007, 06:36 PM   #1 (permalink)
PappaD
PappaD's Avatar
Car: 2005 Chrysler 300C w/5600 miles
Member Number: 11942
Trader Rating: (4)
Shift Point W/Flashpaq
Hello All,
I received my Flashpaq yesturday from a forum member. Everything worked perfect! I know we like to put our foot down as often as possible but, every once in a while I like to just cruise. That's where my problem is... I set the tranny to the sport performance setting and now you have to get the rpm's way up for it to shift and it won't go to overdrive unless you doing 60mph. That can't help gas milage!!! Any help or suggestions would be great. I love the performance but hate the high revs just to shift when cruising.
Thanks in advance,
PD
SpaceCity LX Club Founding Memebr
www.22elite.com
www.tvandnav2go.com
www.universalairsuspension.com
PappaD is offline
Old 05-11-2007, 06:46 PM   #2 (permalink)
rg-300C
rg-300C's Avatar
Member Number: 10041
You could try the custom setting and don't raise the shift points. But keep everything else the way you want it
rg-300C aka Ron
06 300C Cool Vanilla
__________________________
K&N CAI,HID Fogs,SuperChip,SRT8 Spoiler,Stealth Bulbs,$5.25 ESP mod,KW Coilovers V2,Mad Eyelids (VIP),Street Scene Grill,Blastin Bob 7db kit,6000k Halos (AAC),Stealth Auto pedals,28% Tint All Around,6000k Fog Halos (AAC),Leather Console cover (22Elite),LED Tinted Tails (K2 Motors red/smoke),Divici 20" Blade II,Blue LED Grill & Headlights,Custom Engine Cover,DIY Catch Can
More to come:
Mopar Long Tube Headers/Cats soon
rg-300C is offline
Old 05-11-2007, 06:51 PM   #3 (permalink)
PappaD
PappaD's Avatar
Trader Rating: (4)
So in the preset it's all or nothing, correct? Also, can you adjust the idle rpms and turn of the eps with the Flashpaq?
PappaD is offline
Old 05-11-2007, 06:56 PM   #4 (permalink)
lmhoward
Car: 2005 c 300
Member Number: 2497
I don't think I can help you out because I have version 1.0 and have always used the custom tune feature. I use a custom tune with raised shift points (6200 rpm) reduced torque management etc. When I drive normally I don't see any change in shift points, only firmer better shifts and a willingness to downshift immediately with much less pedal. Try using the custom tune feature and see what happens.
lmhoward is offline
Old 05-11-2007, 06:58 PM   #5 (permalink)
PappaD
PappaD's Avatar
Trader Rating: (4)
ok, I wii give it a try. TY
PappaD is offline
Old 05-11-2007, 06:59 PM   #6 (permalink)
rg-300C
rg-300C's Avatar
Yes the presets are just that preset :-).. You can't adjust the idle as far as I know but there is a setting for reduced torque management in the custom settings that reduces the effect of the esp I think
rg-300C is offline
Old 05-11-2007, 11:14 PM   #7 (permalink)
Mrnemo
Mrnemo's Avatar
Car: 2006 chrysler 300c
Member Number: 10309
I did mine using custom setting using 91oct, reduced torque mang. paddle auto kick and I left shift points at stock setting, didn't want to mess with it and it might help you out on your problem. I don't have to rev it up high in order for it to shift. which version are you running?
Mrnemo is offline
Old 05-11-2007, 11:37 PM   #8 (permalink)
PappaD
PappaD's Avatar
Trader Rating: (4)
The new version which is 1.07 I think.
PappaD is offline
Old 05-11-2007, 11:53 PM   #9 (permalink)
Mrnemo
Mrnemo's Avatar
your up to date. have you tried with different settings yet? if so, better , worked?
Mrnemo is offline
Old 05-12-2007, 12:00 AM   #10 (permalink)
PappaD
PappaD's Avatar
Trader Rating: (4)
I will reprogram in the morning. I really like the sport setting just not when I am cruising. I will set it to custom and run that way and see.
PappaD is offline
