Old 06-16-2007, 11:04 AM   #1 (permalink)
Car: 2006 CHRYSLER 300C SRT8
Member Number: 8185
Poked hole in t-stat gasket - will it be ok?
I am changing out my t-stat to the 180 Motorad and when I was prying out the factory t-stat accidently poked a hole the gasket with the screw driver. I think it will be ok, but wanted someone elses opinion. I checked AutoZone and Napa - they don't sell gaskets. Checked with the dealer and you have to buy the t-stat from them for around $35 to get a new gasket. Thanks.
ROCKET is offline
Old 06-16-2007, 02:00 PM   #2 (permalink)
stealthsrt8's Avatar
Car: 2006 Chrysler 300C SRT
Member Number: 7491
i watched a the bee brothers change a t-stat this morning. in fact, we're doing mine right now. that gasket is a bugger. the pressure on the gasket by the t-stat and coolant hose should hold it tightly closed...again, depending on the size of the hole you put in it. like uc45 said, i wouldn't take a chance.
2006 Brilliant Black 300CSRT with AMG Paddle Shifters
Houston's 300,Charger, Magnum, & Challenger Club
stealthsrt8 is offline
Old 06-16-2007, 02:16 PM   #3 (permalink)
Jaxon's Avatar
Car: 2007 Chrysler 300C
Member Number: 12190
Send a message via AIM to Jaxon
Duct tape that b!tch. j/k
Put it on and check if it leaks.
2007 Chrysler 300C Cool Vanilla
Mods: Trying to stay stock.
Cheap ebay grill.
Frankentake III
Eibach Pro-Kit
2 12" JL Audio Sub's
400.1 Rockford Amp.
20% Tint
180 degree T-stat
5% Tint (REMOVED)
Don't tint at HP Racing Customs in Glen Burnie, Maryland.
1964 Ford Galaxie Cream
Mods:
Air Ride
F.B.S.S.
Jaxon is offline
Old 06-16-2007, 04:45 PM   #4 (permalink)
Member Number: 8185
Thanks guys! I didn't want to chance it. I stopped by the dealer and picked up a new 203 t-stat with new gasket. Everything went smooth installing the 180 t-stat with new gasket. No leaks. Now I will get started the noesp fan mod. Thanks.
ROCKET is offline
Old 06-16-2007, 04:55 PM   #5 (permalink)
FreebirdSRT's Avatar
Member Number: 4247
Trader Rating: (10)
Better to be safe than sorry. Glad you went and got a new gasket.
For future ref. do not put the screw driver anywhere near the gasket, to pry up the T-Stat. You want to slip the flat head driver (blue line) under this area (red line) and pry up the T-stat that way. This will protect the gasket.
Also I see you are going to install the Noesp (cool-it fan mod). Let us know how the install went.
Eleanor Roosevelt, 1936
FreebirdSRT is online now
Old 06-16-2007, 10:06 PM   #6 (permalink)
Member Number: 8185
The noesp fan mod is awesome! Very clean install and I like the option of running my fans on high when I want to from my parking lights and the horn confirmation - very cool! Took her out and ran her really hard for about 30 minutes and could't get the engine temp above 185 degrees and the outside temp here in Iowa was over 90 degrees today.
Thanks for the photos and advice regarding the removal of the t-stat to protect the gasket for future reference.
ROCKET is offline
Old 06-16-2007, 10:17 PM   #7 (permalink)
Member Number: 7491
works like a charm.....the trick is getting that same gasket back in, LOL.
Old 06-17-2007, 10:45 AM   #8 (permalink)
Member Number: 4247
Trader Rating: (10)
So which cool it fan mod did you buy? The full auto mode with options to turn fan on high and low, on your own, with horn confirmation?
Old 06-17-2007, 02:37 PM   #9 (permalink)
mjr5150's Avatar
Car: 2006 all options 300C SRT-8 Silver SteeL
Member Number: 4514
You weren't trying to get the car pregnant......were you ??
Glad it worked out for you . I have the GSM fan mod and I've loved it for a year and a half now . A cool car is a happy/fast car .
Options so far :
AIRAID CAI
Dynatech Long tube headers(jet coated)
Corsa cat back system
GSM fan/torque mod
180 degree t-stat
TVANDNAVTOGO(DVD in the front option)
15% tint all around
SRT-8 embroidered mats(Biggest HP gain )
GTS slim visors & fog covers
E & G single mesh grill w/ matching lower inserts(recessed)
Heat polished & ported heads and intake Mani-fold
B&G Stage II Flash(PCM)
Heat TCM flash
Franks Racing Tomahawk Cam
mjr5150 is offline
Old 06-17-2007, 09:22 PM   #10 (permalink)
Member Number: 8185
I went with the manual ($75) fan mod. I didn't feel comfortable tapping into the factory wiring with only 8,000 miles on my ride. I like the option to revert back to stock within a few minutes.
ROCKET is offline
