Old 07-09-2007, 03:43 PM   #1 (permalink)
Pusbum
Pusbum's Avatar
Member Number: 6391
Send a message via MSN to Pusbum Send a message via Skype™ to Pusbum
0 - 60 times
I am sure these times have been posted before but for the life of me I can;t find them......we need danno to do some hardcore searching :-)
Anyway just thought I would see what time people are getting.
I have a stock '06 5.7 and have been consistently getting 6.22 using my flashpaq. I am still trying to work out which flashpaq tune is the best but I am having alot of traction issues
What times are other 5.7's getting?
He who dies with the most toys wins!
Pusbum is offline
Old 07-09-2007, 04:48 PM   #2 (permalink)
va23837
Car: 2007 Chrysler 300C AWD
Member Number: 12314
2007 300C AWD, only mod is kandN intake. 0-60 in 6.1 sec using evic, traction control and esp on.
va23837 is offline
Old 07-09-2007, 04:56 PM   #3 (permalink)
Michaelr
Michaelr's Avatar
Car: 2007 Chrysler 300c
Member Number: 10626
Pusbum - when you do it do you set your system to MPH or measure it as 100KMH? I only ask this as 100kmh = 62.14mph. I other words if you are using KMH your reading will be higher.
regards Michaelr
ps if you are using kmh then your corrected MPH time would be 6.006 seconds
Regards Michaelr
Score B2 M1
Michaelr is offline
Old 07-09-2007, 05:07 PM   #4 (permalink)
Pusbum
Pusbum's Avatar
Member Number: 6391
Thanks Michael but I am using the FlashPaq and it does do it as 0-60 mph :-)
Pusbum is offline
Old 07-09-2007, 09:02 PM   #5 (permalink)
TheCar
TheCar's Avatar
Car: 2006 Chrysler 300c
Member Number: 12632
With Autostick and ESP OFF, you should be in the high-high 5's. There is no reason a 2 wheel drive 300c BONE STOCK shouldn't pull a 5.8 to 5.9 pretty consistently.
It's not good for the car, but you can rev to about 2-3000 RPM with your foot on the brake and release the brake and WOT at the same time and you should see some nice numbers.
AWD should be even better if driven correctly despite the additional weight.
The car has been officially tested between 5.9 and 6.1
I think the car is faster than both numbers, I would say 5.8 is not unattainable.
PS,
THE ONLY TOOL ANYONE SHOULD BE USING IN THEIR CARS TO GAIN TRUE 0-60MPH PERFORMANCE IS THE GTECH PRO SS or RR. THIS IS THEE MOST ACCURATE TOOL OUT THERE.
G-TECH/Pro Homepage
TheCar is offline
Old 07-09-2007, 09:12 PM   #6 (permalink)
Pusbum
Pusbum's Avatar
Member Number: 6391
If I rev my car to 3000rpm with my fot on the brake and then release and WOT I wouldn't move for the first 3 seconds.
Pusbum is offline
Old 07-09-2007, 09:34 PM   #7 (permalink)
TheCar
TheCar's Avatar
If you ease into it, you won't shred rubber, this is where the skill comes into it.
You should be faster than you are.
Weight is a factor, you should be doing this with very little fuel in your tank.
PS,
The "Power Brake" method is used by most magazines to obtain 0-60mph times.
Good Luck.
TheCar is offline
Old 07-09-2007, 10:14 PM   #8 (permalink)
NVS 300
Member Number: 11789
Send a message via MSN to NVS 300
Originally Posted by TheCar View Post
Weight is a factor.....
Jenny Craig?
RATFLMFAO!!!
NVS 300 is online now
Old 07-09-2007, 11:11 PM   #9 (permalink)
TheCar
TheCar's Avatar
Originally Posted by NVS 300 View Post
Jenny Craig?
RATFLMFAO!!!
lol
TheCar is offline
Old 07-09-2007, 11:24 PM   #10 (permalink)
Pusbum
Pusbum's Avatar
Member Number: 6391
lol
Dam! I am screwed! :-(
Pusbum is offline
