Old 07-11-2007, 07:11 PM   #1 (permalink)
Brick Tamland's Avatar
Car: 2006 Chrysler Black 300C
Member Number: 8510
Data Logging - Can someone interpret if there is a problem
Today, my car started to have a seizure when I turned the A/C on. All the dash lights would flash, then go out and the MPH and RPM gauges turned off. The A/C turned off as well, then they would come back on. Then they started to flicker. The car seemed to run fine, but I hooked my S/C up and took some data logs (probably not related) but it did not do any of the above with the handheld plugged in OR with the stock flash installed. Only when the S/C flash was installed. Here are the results:
http://www.net-marketing.ca/engload-timing-rpm.html
Two questions, anything weird with the above data and has anyone had their car act the way mine was today.
PS: It was also acting funny electrically with the A/C off as well....
MY WISHLIST:
[ ]22" Foose Impressions w/ Pirelli Scorpions
[X]Zoomers
[X]AFE Stage 2
[X]Superchip Flashpaq
[ ]Autolumination 300c SuperWhite Overhaul Set
[X]Tinted Rear LED Tail Lights
[ ]Hotchkis Sport Sway Bar Set
[ ]U.A.S. UNIVERSAL AIR SUSPENSION
[X]GTS Chrysler 300C/SRT8 Driving Light Covers
[ ]TommyZ Deep Dish Grill
[X]Alpine IVAW-200 DDin w/ integrated Blackbird
[X]Low Temp TStat (180)
[X]HHP Hi-Flow Cats
Brick's 300c -
http://www.cardomain.com/ride/2612006
Brick Tamland is offline
Old 07-12-2007, 05:40 AM   #2 (permalink)
Performance Moderator
Car: 06 Deluxe! CSRT8
Member Number: 3650
while I cannot analyze your data I can suggest a fix. Many owners have reported loose fuses from the factory. Simply go through each fuse box and remove and re-seat each fuse.
Sometimes this cures the electrical gremlins.
Steve
06 300C SRT8
Only mod is new Toyo Proxes 4
245/45 front 275/40 rear
stevesrt8 is offline
