Old 03-23-2005, 02:34 PM   #11 (permalink)
II kings 9:20's Avatar
Car: 2005 Hemi 300C
Member Number: 132
Yeah, I like M1 also, now that 5w20 is available I'll use it after I run through all my syntec I got on sale for $3.48/qt
II kings 9:20 is offline
Old 03-23-2005, 08:46 PM   #12 (permalink)
ink
ink's Avatar
Member Number: 1711
Do you guys use ramps or just jack the car up? If ramps, can someone refer me to a good set?
ink is offline
Old 03-23-2005, 09:32 PM   #13 (permalink)
Car: 2005 Hemi 300C
Member Number: 132
I use the 12,000lb fiberglass ramps at Autozone, set the parking brake, chock the rear wheels and I use either jack stands or my 3.5 ton hydraulic jack as a safety catch, you will never read about me in the paper crushed under a car. These plastic ramps are great for low slung cars and they claim to work on a vette. I got mine when I could not get my Alfa up the steel ramps. Also the flat part where the wheel sits was short and the stop was low allowing me to drive my Citroen off the ramp luckily I raised the suspension and slid he ramp out, the glass/plastic ramps have a bigger wheel rest and a much higher stop but you want to be very careful easing up the ramp so you don't overshoot it.
Old 03-23-2005, 10:44 PM   #14 (permalink)
ink
ink's Avatar
Member Number: 1711
Hey you can never be too safe right? thanks for the info and the tips....Ill look into those fiberglass ramps.
ink is offline
Old 03-24-2005, 03:31 AM   #15 (permalink)
BrilliantBlackHemi's Avatar
Member Number: 104
The Rhino ABS Plastic Ramps are rated for 12,000 lbs.
Robert
2006 Brilliant Black Crystal 300C SRT8
1999 Bright Platinum Metallic 300M PHP
BrilliantBlackHemi is offline
Old 03-24-2005, 05:21 AM   #16 (permalink)
Car: 2006 Bright Silver, Dk/Lt Slate interior 300C
Member Number: 1615
I have found over the years that all the manufacturers torque the oil filters on really tight. I haven't owned a GM in 20 years, but I hear that they are the same. My Mopars, and Fomoco's were all tough to get the original filter off.
I have a gear drive end cap wrench that seems able to get anything off, although it may crush it a bit.
Model 57 is offline
Old 03-24-2005, 12:33 PM   #17 (permalink)
Car: 2005 Hemi 300C
Member Number: 132
That is the brand I use, I think Wal mart has them too.
Old 03-24-2005, 12:34 PM   #18 (permalink)
Car: 2005 Hemi 300C
Member Number: 132
Same for the idiots over at Mazda, try getting an RX8 filter off.
