Yes, the Predator will be the way to go! JET has a module that plugs in between the PCM and harness and B&G can provide a performance flash but you either have to send your PCM in or purchase a spare to be programmed. The Predator offers alot of features.
Here is a quick rundown -
What is the Diablosport Predator?
The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. The transmission parameters are remapped to improve the shift characteristics such as shift firmness and shift points. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
U7135 Stock Vehicle Tunes:
93 Octane Performance Tune
91 Octane Performance Tune
93 Octane Performance CAI Tune
91 Octane Performance CAI Tune
Modify Factory Tune
U7135 Specific Features:
Idle RPM Drive/Neutral
WOT Fuel 1k-3.8k / 4k-5k / 5k-7k
Rev Limit Drive/Neutral
WOT Spark 1k-3.8k / 4k-5k / 5k-7k
Cooling Fan adjustment
Tire Size
Shift Points(preset values)
Shift firmness(preset values)
Autostick auto upshift enable/disable
ESP enable/disable
TCM adaptive reset
Speed limit
Knock Sensor Enable/Disable
Read/Write time is approx 60 seconds
Clear codes supported
Multiple custom tunes.
All standard DiabloSport Predator features
Hope this helps,
Tom
TBYRNE MOTORSPORTS LLC
ORDER LINE - 1-877-4-TBYRNE (1-877-482-9763)
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE FOR OUR EVERYDAY LOW PRICE POLICY!
