Old 10-03-2007, 06:16 PM   #1 (permalink)
IGOTTASRT8's Avatar
Member Number: 2287
What gear should i use on the dyno?
What gear should i use on the dyno? I've been using 4th because I believe it's one to one. Can I use third? Does it matter?
NX Nitrous Kit With Maximizer 2
Diablo Predator Tuner
GSM Track Mod
Mopar CAI
Zoomers Exhaust
Stant 170 Thermostat
12.2 @ 116 1.99 60ft Famoso Dragstrip
IGOTTASRT8 is offline
Old 10-03-2007, 10:46 PM   #2 (permalink)
BBSRT8's Avatar
Car: 2006 300C SRT8
Member Number: 3224
You are right. 4th gear is 1 to 1 and where you should dyno.
I have done some runs in 3rd gear to compare to 4th gear runs and there was actually very little difference.
Roy
Retired Navy
Options - Sunroof, Option Groups I & II, Rear DVD
Added goodies: PPP 426 Stroker and Ported heads/intake, PPP Turbo cam, B&G stage 4 flashed PCM, Magnaflow catback, 3" high flow cats, DUB CAI, Heat TCM, PI 2800 Stall Torque Converter, KW V2 Suspension, Hotchkis swaybars, GSM Mod, 170 Thermostat, Ultimate pedals
Goodies that I want: LSD and DSS halfshafts (Awaiting install), Turbo (Also awaiting install)
BBSRT8 is offline
Old 10-03-2007, 11:00 PM   #3 (permalink)
Moose's Avatar
Car: 2006 SRT-8 6.1 Hemi 300c
Member Number: 4390
Trader Rating: (4)
You can do a third gear run and even try a second gear run. It all depends on the dyno. You should try a third and a fourth...
Good luck, buddy!!
Moose Burnout here
Highest trap 120 MPH
Fastest reaction time 0.00
Mod list:
Secret Moose Diablo tune
Magnaflow high flow cats
TNT dual nozzle
Corsa cat back
GSM fan mod
180 tstat
Back to Back TO BACK>>Calendar Winner
What happened to us running out of oil?
Moose is offline
Old 10-04-2007, 11:12 AM   #4 (permalink)
Car: 2006 chrysler 300C SRT8
Member Number: 11899
Good luck, buddy!!
yes, you can run in any gear you want. but if you want the most accurrate readings. you should run in 1:1.
Someguys300c is offline
Old 10-04-2007, 10:38 PM   #5 (permalink)
Moose's Avatar
Member Number: 4390
Trader Rating: (4)
You are correct. Still a good idea to get readings of your AFR in low gears.
Moose Burnout here
Mod list:
TNT dual nozzle
Corsa cat back
GSM fan mod
180 tstat
Moose is offline
Old 10-05-2007, 12:19 PM   #6 (permalink)
personally, i do all my original AFR tuning on the street. once i got a good street tune. then ill hit the dyno. then you are basically just messin with your timing on the dyno.
i thought he was simply putting it on the dyno to get a power reading. not do any tuning??
