Old 11-28-2007, 05:15 PM   #31 (permalink)
Points: 5,427, Level: 1 Points: 5,427, Level: 1 Points: 5,427, Level: 1
RobAGD's Avatar
Car: 2005 Dodge Magnum R/T
Member Number: 2842
Send a message via AIM to RobAGD
You still shouldn't be seeing that power dip like that. As a suggestion make some power pull logs and watch that KR like a hawk.
I would also suggest that you get some sort of WB Air Fuel setup so you can see what is going on with the fuel.
The 6.1's are very prone to knock from what I have seen, and it seems like your still getting some.
While I doubt your peak numbers will get much better, tweaking that top end will allow it to continue to pull decently.
Good luck
-R
RobAGD is offline
Old 11-28-2007, 05:27 PM   #32 (permalink)
Points: 7,033, Level: 1 Points: 7,033, Level: 1 Points: 7,033, Level: 1
Power Ported Performance's Avatar
Car: 2006 Chrysler 300c SRT-8
Member Number: 6617
Good luck
-R
we are very well aware of what is causing the dip and have already addressed that last week. KR is all it was.
EMAIL ANDY@POWERPORTED.COM FOR MORE INFO!
Power Ported Performance is offline
Old 11-28-2007, 07:06 PM   #33 (permalink)
RobAGD's Avatar
Member Number: 2842
Andy -
I thought this was his new graph
Is that not his new graph ? That post was on the 25th. Did he mix up his graphs ?
"Andy from PPP fixed it and below are the final results of what heads, cam and bolt ons can do for these cars...."
-Robert
RobAGD is offline
Old 11-28-2007, 07:21 PM   #34 (permalink)
Member Number: 6617
Andy -
-Robert
He went to the dyno for his baseline run and was getting all kinds of KR, so I adjusted his tune and he went back and thats the run you see above, we then revised the tune once more and he hasnt been back to the dyno nor will he. He was obviously still getting some knock up top, and noe that has been smoothed out and eliminated.
Old 11-29-2007, 12:33 AM   #35 (permalink)
Points: 4,308, Level: 1 Points: 4,308, Level: 1 Points: 4,308, Level: 1
damageinc's Avatar
Car: 2007 Chrysler 300c marine blue pearl
Member Number: 12409
Love to see some data on 5.7 with diablo cmr tune,heads and cam set up....so I'll know what Im saving up for.....Any one?
damageinc is offline
Old 11-29-2007, 04:37 AM   #36 (permalink)
Points: 3,721, Level: 1 Points: 3,721, Level: 1 Points: 3,721, Level: 1
Flyntgr's Avatar
Member Number: 1987
Does anyone know of a cmr tuner for the Diablo Predator in Louisiana?
Flyntgr is offline
Old 11-29-2007, 08:36 AM   #37 (permalink)
Member Number: 6617
5.7 block, PPP heads, PPP cam, Longtubes, CMR custom tune by Pro-Motion.
Old 11-29-2007, 08:47 AM   #38 (permalink)
Points: 4,568, Level: 1 Points: 4,568, Level: 1 Points: 4,568, Level: 1
Fabes's Avatar
Car: 2006 chrysler 300c srt8
Member Number: 10310
Sorry if this is not the correct place to post this but can someone please tell me what the new update does and what changes have been made i heard some members say that they don't notice any changes after installing the new update
Brilliant Black Crystal PearlCoated
MODS
1 Tint 35% all around
2 Mats with srt8 logo
3 AFE stage 2 CAI
4 Stock grill painted black
5 Silver licence plate frame with srt logo
6 Key chain with srt logo
7 Valve stem covers with srt logo
8 Mopar Remote start
9 All (TSB'S) completed
10 Painted calipers
11 Centric posi-quite semi-matallic pads
12 300c Hemi Badges
13 180 Tst
14 Diablo Predator
Mods to follow
Hotchkis Swaybar (to be installed )
Fabian
Fabes is offline
Old 11-29-2007, 08:55 AM   #39 (permalink)
Member Number: 6617
Not every update is going to make your car faster. Release 18 (current)(Idle surge fix, Autostick fix for 06-07 5.7L,Autstick feature removed from 07 SRT8, Live data export fix, support for 06 jeep srt8(export),MBT spark adjustment added, knock sensor parameter removed)
DiabloSport :: Gas and Diesel Tuning Systems
Old 11-29-2007, 09:08 AM   #40 (permalink)
Fabes's Avatar
Thanks for the info what do you mean Autostick fix i had the 1-2 flash done please explain
Fabes is offline
