Old 07-19-2004, 12:24 PM   #21 (permalink)
II kings 9:20
II kings 9:20's Avatar
Car: 2005 Hemi 300C
Member Number: 132
Agreed Kev, The Enzo requires Shell synthetic oil at $60/qt 12qt capacity and you void the engine warranty if you don't use it, "that will be $200K for the rebuild please". Yes, $200K is the Ferrari estimate for an Enzo rebuild. I was going with Mobil 1 and got a good deal on Amsoil with Amsoil filters and will be changing it this weekend. There are two other threads discussing all of this. "synthetic vs conventional oil" is the most recent where many of us pontificated on this very topic. Your filter is as important as your oil, see all the info in the other oil threads.
II kings 9:20 is offline
Old 07-25-2004, 12:24 AM   #22 (permalink)
BMWhat?
Car: 2005 Chrysler 300c
Member Number: 223
The example of MB with a class action suit is a rarity. In the millions and millions of cars sold to date, how many class actions law suits have their been due to use of manufacturer suggested motor oil? The MB thing is purely the fault of the engineers at MB... the recommended the wrong oil. Clearly the engine was designed for synthetic use and this with not recognized.
My point is that as long a the minimum spec's are followed in terms of maintenance, most cars will be just fine for a good long time.
Regarding the Enzo, they recommend a specific synthetic oil, so do many many other cars and thus, those requirements of course need to be followed.
BMWhat? is offline
Old 07-25-2004, 08:37 AM   #23 (permalink)
LWOOD
LWOOD's Avatar
Member Number: 166
Send a message via Yahoo to LWOOD
In the U.S. however, federal law dictates that if a manufacturer REQUIRES the use of a specific product for the warranty to be considered valid, i.e. a specific kind of oil, they have to provide that product free of charge. So if we were REQUIRED to use Mobil 1 for instance, than it would have to be distributed to us free. Not the labor for the oil change, but the product itself. So, the costs involved make manufacturers reticent to REQUIRE anything, just "suggest". And if you own an Enzo, you could give a flying fig about the cost of oil!
LWOOD is offline
Old 07-25-2004, 10:54 AM   #24 (permalink)
RobertR
RobertR's Avatar
Car: 2007 Chrysler 300C
Member Number: 254
Changed the oil this week and filled with Mobil 1. Watching temp and noticed the engine running about 12 degrees cooler after the Mobil 1 change.
RobertR is offline
Old 07-25-2004, 10:31 PM   #25 (permalink)
II kings 9:20
Car: 2005 Hemi 300C
Member Number: 132
Watch for a possible class action re: Chrysler 2.7 sludge build up from cooked oil in too small internal oil passages, synthetic does'nt cook without a blow torch. I agree, most situations non synthetic is ok , most of us know someone with 200K+ on thier car on regular oil. I use synthetic for that extra margin, is it absolutely necessary- no, neither was it absolutely necessary for me to get the Hemi, the 3.5 would have been adequate just as regular oil is adequate. For most enthusiasts, adequate is simply not good enough.
Old 07-25-2004, 11:52 PM   #26 (permalink)
BMWhat?
Member Number: 223
Actually, I have a perfect example of where using synthetic saved my butt. I had been using Castrol Syntec in my 89 Taurus V6 and I was driving in humid 90+ weather. I noticed my temp gauge shoot up to just below the red mark. It stayed there while I drove another 10 miles doing 70+ MPH. When I got home, I realized I had blown a hose and had not coolant for quite a while.
The Synthetic keep the engine at a stable operating temperature without any coolant!! Since this event, I've also prescribed to the notion that it's generally a good idea to spend the extra 20 bucks on Synthetic Oil.
BMWhat? is offline
Old 07-26-2004, 10:08 AM   #27 (permalink)
E55 KEV
E55 KEV's Avatar
Member Number: 10
RobertR, what viscosity you using? Mobil-1 does not make 5W-20. Thanks.
E55 KEV is offline
Old 07-26-2004, 10:16 AM   #28 (permalink)
E55 KEV
E55 KEV's Avatar
Member Number: 10
And what makes you think that Chrsyler/MB engineers have not made any mistakes or faults and made an error proof car? The main reason for factory warranty is to cover mistakes made in design, engineering and build.
That is the main/only point behind the Class Action - everyone was following what the engineers recommended and it turn out to be wrong in the long run.
E55 KEV is offline
Old 07-29-2004, 02:12 PM   #29 (permalink)
BMWhat?
Member Number: 223
Actually Kev, engineers make lot's of mistakes. Most of which the consumer never learns about. I say this because I live it every day.
BMWhat? is offline
Old 07-29-2004, 10:21 PM   #30 (permalink)
Hemi_Hombre
Hemi_Hombre's Avatar
Member Number: 463
I've used synthetics for years, primarily Mobile 1 because you can get it anywhere, anytime. And a good filter, like Mobil 1 or K&N (p/n HP 2004).
This web page has great "real-world" application/tests.
http://neptune.spacebears.com/cars/stories/mobil1.html
Hemi_Hombre is offline
