Old 05-28-2008, 07:50 PM   #1 (permalink)
Normgarry's Avatar
Car: 2006 Chrysler 300
Member Number: 17422
Do larger wheels effect the car's Odometer?
I changed my wheels from the OEM 17" to 22"s.
Since I didn't alter my computer at all, did changing wheels effect my Odometer's perception of miles?
A larger wheel rotates slower than a smaller wheel of the same speed.
Normgarry is offline
Old 05-28-2008, 07:55 PM   #2 (permalink)
MurderedOut's Avatar
Car: 2007 Chrysler 300 Base
Member Number: 17322
I don't think you should have a problem.
I have heard of problems with 24s, but even then, rarely.
26s; however, you may run into problems.
I'm not 100% sure, but someone should chime in with a more accurate answer.
Goodluck.
MurderedOut is offline
Old 05-28-2008, 07:56 PM   #3 (permalink)
Member Number: 2536
Yes, it does.
WikiAnswers - Does rim or tire size change mileage
Tire Size/Odometer/Speedo Correction... - Nissan Titan Forums
Tire size calculator
ricardo is offline
Old 05-28-2008, 08:12 PM   #4 (permalink)
jblue21's Avatar
Car: 2006 Chrysler 300c SRT-8
Member Number: 15700
yes it does. the pred corrects it i think if you input the right tire size.
My cars
*2006 300 SRT-8 21,000 miles with the diablo predator and CAI, T-REX grille-fully loaded, 22" crome viper replicas w/nitto 420s stag
*2004 Mercury Marauder Orignal Owner-22,000 miles Vortec Air-to-Air S/C Kit 450rwHP+ w/many other mods(4.10 gears, SCT etc.)
**I'm from Detroit, we don't find anything charming**
**I like fast cars but I aint talkin five-O's**
jblue21 is offline
Old 05-28-2008, 09:01 PM   #5 (permalink)
Kidrock73's Avatar
Car: 2006 Chrysler 300 SRT8
Member Number: 12777
no, not exactly. it depends on what size tire/rim combo you are using. just changing the rims is not the important part. tire size is. yes, you step up on rim size , but surely you went down on the aspect ratio of the tire. so its overall tire diameter that is the important thing. use a tire calculator and compare old to new.
heres an example: 275/45 20 o.d 29.8 -----275/60 17 o.d 30
thats 2 tenths of an inch. so overall tire revs per mile is pretty close. not enough to make a difference. you could change that much from normal tire wear and tire pressure.
my 2cents
2006 CSRT
MAGNAFLOW CAT-BACK
MOPAR CAI
ST COILOVER
22" VIPERS (comp. grey)
CENTRIC ROTORS (drilled/slotted)
DC STRUT BRACE
Billet Tech wing emblem f/r (traditional ribbon-black anodized)
CARBON FIBER DASH KIT
CUSTOM STEREO
Kidrock73 is offline
Old 05-29-2008, 06:45 AM   #6 (permalink)
pukkaSRT8's Avatar
Car: 06 Chrysler 300C SRT-8
Member Number: 12019
Trader Rating: (10)
as kidrock mentioned, as long as you kept the rolling radius within spec you shouldnt have a problem.
300C SRT 8 SILVER STEEL . . . . . . . . . . . . . . . . . . Fully Loaded - Lightly Modded
PUKKA pron. puk·ka [adj.] genuine, authentic, first class
pukkaSRT8 is online now
Old 06-06-2008, 09:59 AM   #7 (permalink)
bbmakmak's Avatar
Member Number: 13497
yeah if I drive at 45 miles per hour I am actually going 48-50 MPH because I have 22s on.
22s black. tint. 6000ks
bbmakmak is offline
Old 06-11-2008, 12:15 PM   #8 (permalink)
xft116's Avatar
Car: 2005 chrysler 300
Member Number: 17006
i went from stock 17s to 22s and a buddy of mine is a cop so we checked it out and when my speedo says 70 i was actually going 75 i didnt think it would be that far so i tested with gps also it was accurate 70 on the speedo
was really 75
xft116 is offline
