Performance Modifications Discussion about performance enhancing parts.
300cForums.com is the premier Chrysler 300C forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 07-15-2009, 11:00 AM   #61 (permalink)
Points: 10,409, Level: 1 Points: 10,409, Level: 1 Points: 10,409, Level: 1
mexi's Avatar
Car: 06 Chrysler 300c
Member Number: 3761
Trader Rating: (4)
Send a message via AIM to mexi
hmmm with my sidewinder i got better 60ft and a ton of low end torque...my best 60ft so far is a 1.79 before the cam i was 2.0*'s
here is a vid of mine leaving the line RaceVideoForums.com MMP TNT Mexi 300c 12.4 HD - Car Videos on StreetFire
FRANKRACING ECONO HEADS + SIDEWINDER cam
staggerd lexani 22's
Tommyz grill
tinted tails
JBA shorties and mid pipes
AFE stage II, billet tech catch can and acc.
best track time 12.4 @110.93
mexi is offline
Old 07-15-2009, 11:09 AM   #62 (permalink)
Points: 12,123, Level: 1 Points: 12,123, Level: 1 Points: 12,123, Level: 1
turbohips's Avatar
Car: 2005 Chrysler 300c AWD
Member Number: 952
Well another reason why my 60 probably hasn't improved is the fact the last two times at the track I had a DA of 4400+ and 3500+. I'm sure with a negative or zero DA I would have a much different result.
Volant CAI, JBA headers, JBA cat-less mids, Borla exhaust, Inertia Street heads, Spartan cam 114 LSA, underdrive pulley, 180 thermo, programmer, hotel seo, hotel printing, hotel marketing still looking for a stronger AWD trans though.
turbohips is offline
Old 07-15-2009, 02:12 PM   #63 (permalink)
Points: 19,102, Level: 1 Points: 19,102, Level: 1 Points: 19,102, Level: 1
Member Number: 6420
I don't think that DA has too much an effect on your 60 foot time. Now overall e.t. - somewat, and trap speed - definitely. 60 foots are very dependant on track prep and car prep.
The Sidewinder is a proven 5.7 cam, not many better.
Eric
In Ohio - stock with AFE II intake 12.94@109.1 2.00 60
- added Magnaflow HF cats, CORSA and Predator with CMR tune by Ken Bjonnes at DCX Depot...and 4128 t-stat & BT catch can
Bests(all done on Toyo 255s):
-Now in ABQ, new CMR tune from Dave Rochau @ Motiva/Hellion and a 4127 tstat
EricG is offline
Old 07-15-2009, 04:17 PM   #64 (permalink)
turbohips's Avatar
Member Number: 952
Come one Eric you're telling me that regardless of the DA my 60 foot times wouldn't be different? My car and the track prep doesn't really mean much to AWD guys. If your reasoning is correct that wouldn't explain how my 60 foot times got better when the air was cooler on the same track and with a lower DA later in the evening. DA absolutely has something to do with 60' times. My cam is larger than the Sidewinder so I should have more torque.
Old 07-15-2009, 04:47 PM   #65 (permalink)
Member Number: 6420
I dunno...maybe it's different for AWD, but I stand by my statement - for my car anyway.
Eric
EricG is offline
Old 07-15-2009, 05:28 PM   #66 (permalink)
Points: 11,062, Level: 1 Points: 11,062, Level: 1 Points: 11,062, Level: 1
yamabob's Avatar
Car: 2007 chrysler 300c
Member Number: 14746
Steve, what would be a good stall speed for the torque convetor
AFE, Corsa Catback, Predator,HHP High Flow Cats,JBA Shorties,HHP Stage1 cam,HHP CMR tune,6000k HID low & fogs,AAC 6k halos,Original American Illuminated Rear wing 347 rwhp,375 rwtq,20" chrome SRT rep's,rear SRT trunk spoiler,SRT front lip. Luxer interior LED's, Grip grill,22Elite console cover
yamabob is offline
Old 07-15-2009, 06:00 PM   #67 (permalink)
Points: 9,664, Level: 1 Points: 9,664, Level: 1 Points: 9,664, Level: 1
lethal300c's Avatar
Car: 2007 Fiat 300C
Member Number: 18258
Trader Rating: (10)
I'd have to say Eric is right, to a point. DA in itself should not have a huge impact on 60' times, depending on the largest part factored into the DA. The heat soak that occurs, and is largely part of the DA at lower altitude tracks, is the problem. Since you are running in the area of Fontana, heat is the single biggest challenge you have, and the largest contributer to a high DA. Damn near impossible to get your engine cooled enough for decent runs in extreme heat or humidity. Getting it cooled just in high altitude is a different story.
Going with that, the DA (heat/humidity) killed me my last time out. My best 60' is 1.81 this last spring with a DA of around -300 or so. About a month ago (with 75-80 more whp thanks to heads/cam) my best was 1.97 in a DA of +3300 and worse. Now on that outing track prep sucked and I still do not believe I could have matched my previous best, even if track prep was damn near perfect.
You will get better 60' times turbo, once it cools off a bit. That is my story, and I am sticking with it.
Edit: Sorry bob, did not mean to hijack your thread.
Keith
PPP Stage III Heads/Cam * K&N CAI * ARH Long Tubes w/High Flows * Borla 125 Aggressive Exhaust w/5" Tips * DMH Low Profile Cutouts * DiabloSport w/CMR Tune * Zex Nitrous * PI 3600 TC * 1,000+ HP Tranny Upgrade * Black LED Tails * TIS03 22" Wheels * And many more
You will be sorely missed Mr. iNCREDIBLE! Thanks for everything you have given to this group. I'll see you on LXF.
lethal300c is offline
Old 07-16-2009, 06:27 AM   #68 (permalink)
Performance Moderator
Points: 14,432, Level: 1 Points: 14,432, Level: 1 Points: 14,432, Level: 1
Car: 06 Deluxe! CSRT8
Member Number: 3650
many
Ideally you would look to the cam spec to decide, but in these cars you can go WAY higher than I normally would due to the trans design.
3000 rpm looks like the norm to me.
J. William Fulbright
Steve
06 300C SRT8 all stock
stevesrt8 is offline
Old 07-16-2009, 08:33 AM   #69 (permalink)
yamabob's Avatar
Thanks Steve. At least this will be a relatively cheap mod
Keith-no need to apologize. I find your postings entertaining and somewhat pertinent to a cam job. It's all good! Now Steve has helped me with my personal stimulus package. Keep up the good work guys!!! Only problem is I only get to enjoy the car 1 to 2 days a week max at this point. I'll be back to her tonight though and plan on "breaking" in the cam job as best as I can. I'll let ya know if I feel any difference.
yamabob is offline
Old 07-16-2009, 08:53 AM   #70 (permalink)
Member Number: 6420
Thanks Keith, and I should have elaborated a little more maybe. Track prep you cannot control really, but car prep is important. Same tires, same PSI, same weight, and controlling your car's temps etc are crucial...and when you want to compare before and after or try to measure the weather's effects you need to control all these other things. That's all I meant, and when you do all that I bet you would find that your 60 foots would not change that much day to day regardless of the weather if the car's modifications are held constant.
Eric
EricG is offline
