Old 10-12-2009, 01:28 PM   #1 (permalink)
Points: 4, Level: 1 Points: 4, Level: 1 Points: 4, Level: 1
Car: 2006 Chrysler 300c
Member Number: 24154
Mopar TCM
I bought a mopar tcm for my 2006 300c and I have a question about it. I searched but couldnt seem to find a specific answer:
While reading the install directions, it says that the mopar PCM is required to install the TCM.... is that true? I heard from someone at the dealer that it wasnt needed. My car is basically stock besides a mopar cai and custom catback.
is the pcm really needed.... or can I install the tcm on the car as it is now? is it (pcm) worth it? can something like a diablo predator be used instead?
sincityhemi is offline
Old 10-12-2009, 10:15 PM   #2 (permalink)
Points: 2,668, Level: 1 Points: 2,668, Level: 1 Points: 2,668, Level: 1
Moebius44's Avatar
Car: 2005 Dodge Magnum
Member Number: 10921
No, it is not; however to extract all the MOPAR TCM has to offer it is very important to follow the installation instructions. The difference between a proper and improper installation is significant...
HEMISSARY
Moebius44 is offline
Old 10-22-2009, 05:04 PM   #3 (permalink)
Points: 3,364, Level: 1 Points: 3,364, Level: 1 Points: 3,364, Level: 1
saleen8927's Avatar
Car: '06 Chrysler 300C SRT8
Member Number: 20505
as Moebius said, I don't think you need the PCM. I used the TCM without it and it worked fine. I >do< recommend the Predator in general, but do not install a tune while the Mopar TCM is connected or you will wipe it clean. While installing a predator tune, plug the stock TCM back in, then replug the Mopar TCM in after it's installed. You can, however, raise shift points/rev limiter with the Predator without wiping the TCM (I believe...didn't seem to wipe mine, but take that advice at your own risk).
The Predator just makes a big difference on these cars all around.
2006 300C SRT8 - Silver Steel - Predator, Janetty Racing CMR Tune, 180 TStat, AFE Stage 2 Intake, Satisfied Ceramic Pads, Toyo Proxes 4, 20% Tints, T-Rex Upper Class Grille, 6000K CCFL Halos, 6000K HIDGate Replacement Lows, 6000K HIDGate Fogs, Stealth Front & Rear Signal Bulbs, Stealth Clear Side Markers, Tinted Tails
saleen8927 is offline
Old 10-22-2009, 05:15 PM   #4 (permalink)
Moebius44's Avatar
You can change gear ratio as well...
