Time to Replace Tires - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Performance Forums > Performance Wheels & Tires
Performance Wheels & Tires This section is for all discussions related to the performance aspects of Wheels & Tires.
Old 11-09-2012, 10:04 AM   #1 (permalink)
Points: 608, Level: 1 Points: 608, Level: 1 Points: 608, Level: 1
Member Number: 38568
You guys have always been a good source of info so I have another question.
I have a 2008 SRT Design with the 20" rims x ?? wide. I really don't much care for performance tires especially living in Chicago. I would like the widest tires I can put on these rims and still be able to rotate. I would put ride and comfort in all seasons first, followed by performance and lastly tread wear but still should be 40k. I like the low profile look so I would like to stay with that if reasonable for ride and comfort.
What is the opinions on best tire? Thanks.
Jeffko is offline
Old 11-09-2012, 11:41 AM   #2 (permalink)
Points: 28,967, Level: 1 Points: 28,967, Level: 1 Points: 28,967, Level: 1
MADDOG's Avatar
Member Number: 11602
As far as the best tire, I'll defer on making a suggestion there.
As far as size, 255/50x20 or 245/45/20 would work great. You can go to a 275/40x20 all the way around but the front could rub a bit in a full turn.
Look for a tread wear rating of 300 (sometimes known as the durometer) or higher. The higher the number, the less "performance" you'll get. You end up trading wear for stickiness.
Lots of brands out there to choose from. My experience with the stock Continentals and Goodyears was very, very poor.
Nitto, Michelin, BFG and Falken are all brands I have used in the past with good results. I currently run Toyo Proxes 4 tires, 245/45x20 on the front, 275/40x20 on the rear.
You might also look into the Hankook line. I hear good things about them but have no experience with them.
Michael
MADDOG is offline
Old 11-09-2012, 12:05 PM   #3 (permalink)
I'm assuming those tire sizes will give the same circumference or is there a digital adjustment that can be made with the intune?
Rear wheel drive and snow is a consideration, but so is the fact snow is on the roads just a few days a year and for not very long.
How do those Toyos ride?
Jeffko is offline
Old 11-09-2012, 01:08 PM   #4 (permalink)
MD - it appears you have nailed it again or at least for sure MoparMax agrees with the Toyo Proxes 4+ tire. See the link below...thanks again!
:::MoparMax::: Product Review - Toyo Proxes 4 Plus Ultra-High Performance All-Season Tire - 8/2/2012
Jeffko is offline
Old 11-20-2012, 09:34 AM   #5 (permalink)
MD - are you sure 275/40x20 will fit on my rims? I have an SRT Design with 20" rims that look like the actual SRT but I'm not sure they are 9" wide? Thanks, Jeff
Jeffko is offline
Old 11-20-2012, 10:37 AM   #6 (permalink)
Points: 2,402, Level: 1 Points: 2,402, Level: 1 Points: 2,402, Level: 1
Car: 2012 CHRYSLER 300S V8 RWD
Member Number: 21453
Hey. I had a 2008 300 SRTD in chicago for 3 years. Traded it in about a year ago...but I went through 3 different sets of tires. My favortie BY FAR was the yoko parada Spec-X. I went in the 255-50 size. Grip for days...awesome in the snow as well. They have a very agressive tread pattern, but they were also quiet and wear was average/above average. When I bought them in 2010/2011 they were about 125 a piece.
The SRT Design rims are 8'' I believe....so I would shy away from anything wider than 255 so they wheels dont bulge when mounted.
rvaldez1 is offline
Old 11-20-2012, 10:48 AM   #7 (permalink)
Warning to any of you guys changing tires on an SRT/ DESIGN. You do not have actual SRT rims which are 9" wide. They in fact are 8" wide and the max tire width is 255.
I am reordering the Toyo Proxes 4+ as 255/45x20. Through some research and questions I have decided this tire will give me a slightly better contact patch and will ride a little smoother as well with the greater sidewall height. The difference between the 245/45x20 stock tire and the 255 is about 10 revolutions per mile. The 255 is 1.26" more in circumference. So all this mean my computer will be off by about 151' more distance traveled per mile or 2.865%. This will effect a 60mph odometer reading to be actually 61.7mph. I can live with that and am anxious to get the new tires on. Read the link above to see why I'm looking forward to them.
Jeffko is offline
Time for new tires on the CSRT8. Any suggestions on where and what? (Moved) RTP SRT8 SRT8-Specific Wheels/Tires/Brakes/Suspension 18 02-25-2009 12:23 PM
Need to replace tires on AWD. What to get? Denver300C Custom Wheels & Tires 12 10-22-2008 03:50 PM
Do I need to replace both front tires? lchinski SRT8-Specific Wheels/Tires/Brakes/Suspension 2 07-14-2008 10:52 AM
What did you buy to replace your stock tires? And cost guesses? :) OoTLink Custom Wheels & Tires 5 10-05-2007 09:06 PM
one more time-tires for the SRT8 SRT8C SRT8-Specific Wheels/Tires/Brakes/Suspension 26 03-03-2007 09:07 AM
