Go Back   Chrysler 300C & SRT8 Forum > Supporting Vendors > Power Ported Performance
Old 12-08-2007, 06:41 PM   #1 (permalink)
Power Ported Performance's Avatar
Car: 2006 Chrysler 300c SRT-8
Member Number: 6617
PPP Shortblock info!
With all of the new competition out there, we decided to spend a little time in detail about our new engine offerings.
1. We start by inspecting and disassembling the shortblock core
2. Hot tank the block and remove all liquid contaminents
3. Sonic check all cylinder bores
4. Clean oil galleys
5. Bore scope cavities
6. Hand chase threads
7. Validate deck surface
8. Validate Bore Centerlines
9. Bore cylinders
10. Hone cylinders with honing plate
11. Line Hone
12. Hand Clearance for Stroker Kit
13. Balance rotating assembly(we do not depend on factory balance)
14. Install Cam bearings
15. Remove all flashings
16. Chafer all 90 degree corners
17. Radius bottom of all cylinder bores
18. Maintain .0625 chamfer radius throughout oil system
19. Micro-polish all bearing surfaces including wrist pins
20. Micrometer measurement of all bearing surfaces
21. hand match individual bearings to journals maintaining .0001" tolerance to specified clearances
Components include the following:
K-1 Billet 4.080 crank
K-1 H-Beam connecting Rods
JE Nascar grade pistons
ARP main studs
ARP head studs
Cleveite H Type Main and Rod Bearings
Dura-bond Cam Bearings
Mopar Performance Block Plugs
Miscellaneous Parts (missing plugs, clips, etc…)
Here is some info on K-1
http://www.k1technologies.com
Here is some info on JE Pistons
www.jepistons.com
Without going into too much detail, our engine builders mainstay is building R5P7 356 cubic inch Nascar engines making 800+ horespower. With this capability, its no wonder that we carry an industry leading 3/36,000 mile warranty on our blocks even when supercharged/turbocharged. We are confident that this block is going to further seperate us from the competition and look forward to the new year. As for pricing
Shortblock: $6599
Core Charge: $1200
Longblock: $10999
Core Charge: $2200
Longblock includes the 426/392 shortblock, PPP record setting Stage 2 heads, Cometic head gaskets, forged pushrods, new rocker arm assemblys, new timing chain and sprockets, new timing cover, and camshaft of your choice. Both shortblocks and longblocks come with the 3/36,000 mile warranty. Call today to place your order.
EMAIL ANDY@POWERPORTED.COM FOR MORE INFO!
Power Ported Performance is offline
Old 12-08-2007, 07:26 PM   #2 (permalink)
Jected
Jected's Avatar
Car: 2007 Chrysler 300C SRT8
Member Number: 9663
Can the engines be built to suit specific applications. For example supercharging. What sort of input can we put in to this build? Shipping internationally, is that ok? Can arrange own couriers if need be and would probably prefer that due to the rates we have.
Thanks.
RDP built 426 (incls. custom internals - Boost 20psi)~RDP-Bullet/Harrop supercharger~RDP CAI~RDP Custom Tune for supercharged 426 SRT8~RDP Custom fuel rails~HP/F custom fuel &Intercooler system~RDP/DSS 1000hp Half Shafts~Kooks Headers~Zoomers cat back~Precision Industries 3400 convertor~22" Black/Chrome Sevas Staggered - Fronts 22x9 (265/35) & Rears 22x10.5 (295/30)~Lowered~Mopar Grille~Kicker sound system.
http://www.300cforums.com/forums/avatars/jected.gif?type=sigpic&dateline=1210167973
Jected is offline
Old 12-08-2007, 09:08 PM   #3 (permalink)
Member Number: 6617
Thanks.
We can do higher/lower compression, we can ship wherever you want, in fact we ship several engines per year overseas.
