What problems will cracked bushings cause? - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 12-18-2012, 04:02 AM   #1 (permalink)
Points: 2,068, Level: 1 Points: 2,068, Level: 1 Points: 2,068, Level: 1
Member Number: 1671
My dealership informed me that I have cracked bushings. I was wondering what problems this will cause if not fixed right away (since it is kind of expensive to do at the dealership).
Faris Kalin is offline
Old 12-18-2012, 05:54 AM   #2 (permalink)
Points: 6,932, Level: 1 Points: 6,932, Level: 1 Points: 6,932, Level: 1
Activity: 51% Activity: 51% Activity: 51%
therealfleen's Avatar
Member Number: 40424
Change them yourself!
How To: Remove/Install Sway Bar Bushings
05 300c
LMI Frankentake IV
Predator 93 Oct Tune
Billet Catch Can
Jet 180 T Stat
therealfleen is offline
Old 12-18-2012, 07:15 AM   #3 (permalink)
Points: 34,368, Level: 1 Points: 34,368, Level: 1 Points: 34,368, Level: 1
Member Number: 1483
Which bushings?
DESIREE is offline
Old 12-18-2012, 03:13 PM   #4 (permalink)
Member Number: 1671
Originally Posted by DESIREE View Post
Which bushings?
The strut bushings. The dealership wanted $600 for both sides since they said they couldn't just replace the bushings by themselves and needed to replace the full arm.
Old 12-18-2012, 03:13 PM   #5 (permalink)
Member Number: 1671
Originally Posted by therealfleen View Post
Unfortunately, I have essentially no car repair skills.
Old 12-18-2012, 04:38 PM   #6 (permalink)
Points: 28,673, Level: 1 Points: 28,673, Level: 1 Points: 28,673, Level: 1
MADDOG's Avatar
Member Number: 11602
Worn bushings will eventually cause damage to other components. They are designed to allow components to move without metal to metal contact and/or to provide a form of shock cushiong within a system, such as your suspension system.
It's better to do the repair sooner rather than later. It's much like worn brake pads. It's cheaper to replace just the pads vs. waiting until you've damaged the rotors.
Michael
MADDOG is offline
Old 12-18-2012, 06:46 PM   #7 (permalink)
Member Number: 1483
Forget the stealership! The bushings of the tension strut can be replaced, but it's hardly worth it what with the ball joints on the opposite end of the strut having the same number of miles on them. Complete strut assemblies are available online for like $60 or so each. A 'shade tree' mechanic with a few decent tools (jack, jack stands, sockets, ratchets, open,box wrenches, "pickle fork", penetrating oil, breaker bar, screwdrivers, etc.) can do the job in his driveway, as I and many others have done, in 2-2&1/2 hours. An experienced independent mechanic could easily do it in less than 2 hours. At $75-100/hour the total comes to $270-$320.
I have written a DIY (complete with lots of pictures) based on my experience. If you would like it drop me a PM with your e-mail address and I'll send you a reply with the DIY attached.
EDIT: Frontend squeaks and clunking, eventually with excessive tire wear due to misalignment.
Last edited by DESIREE; 12-19-2012 at 10:27 AM. Reason: To answer the original question "What problems will cracked bushings cause? "
DESIREE is offline
The Following User Says Thank You to DESIREE For This Useful Post:
Northern Rider (12-18-2012)
Old 12-25-2012, 03:55 AM   #8 (permalink)
Points: 103, Level: 1 Points: 103, Level: 1 Points: 103, Level: 1
Car: 300c 2007 Chrysler 300c
Member Number: 42160
Hi I have been trying track down a creeking noice coming from the front when I enter in to a turn, I have now replaced on both sides the upper controll arms, the track rod ends, both the lower control arms, all the ball joints, the wheel Berings and discs and pads. I have also had all geometry checked and corrected and I am still getting a Creeking noice from the front end, it is driving me nuts. Can any one help? Or has any one had the same problem?
Cheers
Shamalj7nnn is offline
Old 12-25-2012, 03:56 AM   #9 (permalink)
By the why this is all on my 300c
Old 12-25-2012, 06:04 PM   #10 (permalink)
Points: 1,468, Level: 1 Points: 1,468, Level: 1 Points: 1,468, Level: 1
Member Number: 25146
Pedders will be able to perform an inspection and report of your suspension and steering. They should only charge $20 or so.
Have you taken it to a professional suspension shop for their opinion?
Just a suggestion - have you checked or changed the power steering fluid? Sometimes the power steering pump can give a creaking noise during turns.
eltech is offline
Help! cracked radiator sully83699 General Discussion 1 10-17-2010 08:10 AM
this cracked me up Derek Mc European & Diesel Powered 300 Models 7 11-28-2007 01:05 PM
Cracked a wheel---need another one RobinVA Custom Wheels & Tires 9 10-12-2007 08:44 AM
Cracked Rims DAKOTARACER47 Custom Wheels & Tires 3 12-06-2006 12:12 PM
gas pedal cracked... mag300cSTL Problems / Dealer Service 10 03-05-2005 11:23 PM
