Old 09-05-2004, 08:03 AM   #1 (permalink)
joey
Member Number: 232
Smile Hours driven and average mph indicator
I think I found a formula to calculate our average driving speed, or something similar to how Nascar calculates average track speed during a race. With the hours driven and miles driven, an average mph can be calculated.
Turning the key to acc. and pressing the miles reset button will display the number of hours, which I assume is the number of hours the car is running, not moving.
By using this formula, I figured out my average "track speed" is 26 mph.
((Total miles driven / 60(mph)) / hours driven) x 60mph = avg track speed
In my case I have driven 359 miles in 14 hours.
((359 / 60 = 5.98hours) / 14 hours) = 42% x 60mph = 26mph
26mph avg seems low to me and may explain why I am only getting 13 mpg.
The theory is, a lower number assumes a lot of stop-and-go and idling time at stop lights. A higher number would imply more highway speeds, which would get better mpg.
I was reading on another forum where folks were posting their hours and miles driven. When I did the calculations, one guy was averaging as high as 48mph (he lived in Arizona), and all of them were higher than mine.
I live in Silicon Valley and my commute on the way home is pretty slow.
I guess I need to get out more and stretch my legs.
Anyway, thought this might be interesting for folks interested in crunching some numbers.
joey is offline
Old 09-05-2004, 08:52 AM   #2 (permalink)
Gary C
Gary C's Avatar
Car: 2005 Loaded & Bagged C
Member Number: 610
The Dodge Diesel I have does the same, good info
2005 300C Black Bagged 22z
Gary C is offline
Old 09-07-2004, 09:56 PM   #3 (permalink)
upstate
Member Number: 73
I'm missing something. I turn my key to acc. and then press the trip reset and nothing happens except resting the tripodometer. What gives?
upstate is offline
Old 09-07-2004, 10:26 PM   #4 (permalink)
joey
Member Number: 232
Keep pressing the reset button for about 6-8 seconds. It should then display the hours. Do you have 300c or 300? My trip miles don't change when I push the trip reset button.
joey is offline
Old 09-11-2004, 04:19 PM   #5 (permalink)
catchMEifUcan
catchMEifUcan's Avatar
Car: 2005 Chrylser 300C
Member Number: 449
I think the computer is wrong. The timer runs even when the car isn't running. I have gone back to computing the MPG by taking trip A reading and dividing it by the amount of fuel I just added. So, 360 / 18 = 20 MPG. The computer tells me 16.8MPG. Ha!
2005 300c Magnesium, loaded, built May 14th, 2004 @3PM
2008 Towne and Country Limited
1992 Isuzu Amigo 4x4 2.8 Red, off-road suspension
catchMEifUcan is offline
Old 09-11-2004, 05:10 PM   #6 (permalink)
joey
Member Number: 232
Hours Driven and Elapsed Time should be same number.
The attached picture is someone else's Hours Driven. I don't have a picture of Elapsed Time.
The Elapsed Time can be found by clicking on the Menu > and scrolling to Elapsed Time, which will show the Hours:minutes:seconds.
Elapsed Time only changes when the car is running. I just verified this.
But your MPG calculation (360 miles / 18 gallons = 20mpg) doesn't use Hours Driven or Elapsed Time. So why did you conclude "The timer runs even when the car isn't running"?
joey is offline
Old 09-11-2004, 05:52 PM   #7 (permalink)
catchMEifUcan
Member Number: 449
Last time I was sitting the car after turning off the key, the EVIC's timer kept counting.
Maybe it's a glitch?
Old 09-11-2004, 05:55 PM   #8 (permalink)
mileshoover
mileshoover's Avatar
Member Number: 85
Dependent upon your EVIC Personal Settings, the car's electronics will continue to function so long as neither front door is opened. Once one is opened, all activity ceases.
Miles
mileshoover is offline
Old 09-12-2004, 06:18 AM   #9 (permalink)
upstate
Member Number: 73
I have a 300C and can not get this to work. Once I press the mileage reset botton in this fashion it resets the miles. This occurs in A or B.
upstate is offline
Old 09-12-2004, 12:14 PM   #10 (permalink)
jeepgrady
jeepgrady's Avatar
Car: 2005 C 300
Member Number: 415
You probably have the old software dated 2/24/04, like I do. This hrs. feature apparently only works with the new software which I beleive is dated 6/11/04.
You can check which version, as well as other good stuff by simultaneously pressing, and holding the compass and the music button on the steering wheel for about 5 seconds.
jeepgrady is offline
