Old 08-30-2004, 09:40 AM   #11 (permalink)
Gary C
Gary C's Avatar
Car: 2005 Loaded & Bagged C
Member Number: 610
Originally Posted by BrilliantBlackHemi
I will look at the ability to install the Amsoil Bypass Oil Filtration System on my Hemi sometime. Got to get the car first.
the diesel boys(pickup) run these ,,,, the first time I saw a diesel truck with perfectly clean oil BLEW MY MIND, I asked how many milies, he said 25000,,,, gettting this system on my Cummins pickup in about 8000 miles,,, we have a 20000 mile break in.......
2005 300C Black Bagged 22z
Gary C is offline
Old 08-31-2004, 08:49 AM   #12 (permalink)
SilverHemi
SilverHemi's Avatar
Member Number: 160
The TP filter is fine in theory but as one person pointed out, acids will build up over time. Another problem is that additive levels will deplete over time,
leaving you with non detergent lawn mower oil in your 40K ride. It will look clean though! The guy rebuilding it at 100K miles will marvel at the cleanliness of the oil as he scrapes the gunk off the internal surfaces.
SilverHemi is offline
Old 08-31-2004, 09:53 AM   #13 (permalink)
coolvanilla
coolvanilla's Avatar
Member Number: 524
Just had my first oil change at the dealer. The dealer recommended synthetic is Mobil 1 5w30. Hope it doesn't effect the MDS!
coolvanilla is offline
Old 08-31-2004, 05:24 PM   #14 (permalink)
jeepgrady
jeepgrady's Avatar
Car: 2005 C 300
Member Number: 415
The Hemi specifies 5-20W, period. Don't go by what the dealer says. He may only have 5-30W
jeepgrady is online now
Old 08-31-2004, 06:58 PM   #15 (permalink)
coolvanilla
Member Number: 524
If we have to stick with 5w20 it appears the only true synthetic is Redline?
Old 08-31-2004, 10:10 PM   #16 (permalink)
toothdoc
toothdoc's Avatar
Car: 2005 mag 300c
Member Number: 251
mobil 1 has 0w 20 that states for use in cars that require 5w 20?? Thats what I put in mine
toothdoc is offline
Old 09-01-2004, 10:11 PM   #17 (permalink)
II kings 9:20
II kings 9:20's Avatar
Car: 2005 Hemi 300C
Member Number: 132
I agree, my plan is to go with 0w20 Mobil 1. My dealer also said 5w30, they have absolutely zero experience with MDS and are in no position to make an intelligent comment on the issue. If you are using synthetic,I really doubt 5w30 would hurt but I too have zero experience with MDS and really don't know sh*t from shinola about this system long term. Regular 5w30 is different all together and may "coke" or sludge up the MDS system. I really think the 5w20 is all about Cafe, but DC strictly advises against premium fuel in the Hemi, 89 is preferred and 87 is OK so who knows if 5w30 is ok long term. I would like the manual to say 5w30 is ok just as it says synthetic is ok.
II kings 9:20 is offline
Old 08-16-2007, 07:16 PM   #18 (permalink)
TheJackal24
TheJackal24's Avatar
Car: 2006 300C SRT8
Member Number: 4907
Had to bring this back since I just added on the amsoil bypass.
I just added on the amsoil bmk13 remote dual mount kit and 10" filter. Purpose: to get cleaner oil and reduce oil changes...
This is a well built kit but I do have my concerns. Anyone getting this kit should find a place to mount it. I found only one place (without much disassembly), on the frame under the air filter. My concerns are that my oil pressure has dropped under load. I've read a few reasons for this but find them difficult to explain a 15psi drop. Usually under load (cruising the freeway) I have a 55psi. Now under load I have 40psi. I will call amsoil tomorrow to try and get an explanation. I would have expected a small drop due to the length of the line run from the filter's old location to its new location, but not that much. Anyone wishing to drop in their $.02 may do so. I will post after speaking with amsoil tomorrow. The drop is less at idle (Usually 24, now 21).
TheJackal24 is offline
