Old 05-22-2006, 10:23 AM   #1 (permalink)
Car: 2006 chrysler 300c srt8
Member Number: 5577
fog light foggy
my fog lights have water in them somehow and have stayed foggy for weeks. what can i do?
handsrt8 is offline
Old 05-22-2006, 11:55 PM   #2 (permalink)
Spock1's Avatar
Car: 2006 Mazda 6 Wagon
Member Number: 4088
Same thing happened to my right fog light. It looks like I have a stone chip on the lens surface. It was foggy for about a week or so and then just cleared up of its own accord.
Take it back to the dealer and get them to check the seals.
Cheers
Sean
"For those who like this sort of thing, this is the sort of thing they like." Abraham Lincoln
Spock1 is offline
Old 05-24-2006, 09:09 AM   #3 (permalink)
DanRealtor's Avatar
Member Number: 3102
Foggy Lights
They are relatively easy to remove and clean. I know because I had a bulb explode inside so I had to remove it to clean out the debris.
In the wheel well are some "Jap Clips" that are designed to be opened and reused. They run along the edge of the front fender. There is a special tool used to pop them. A flat screwdriver will work to pop the clips open. There are also a couple of screws on the bottom with hex heads. After you remove the screws and pop 3 or 4 of the clips open you can reach in and twist the fog light wire/bulb counter clockwise a 1/4 turn and remove it from the housing. Then there are 2 Torx head screws that hold the fog light housing in place. Remove them and the housing pulls out from the front. Use compressed air and/or a clean rag to remove any moisture and/or dirt from inside the housing. Use a bit of rubbing alcohol to clean the bulb before reinserting. It's all pretty straight forward.
It Wasn't Me
(well, maybe once it was)
DanRealtor is offline
Old 05-28-2006, 08:32 PM   #4 (permalink)
steve 300c's Avatar
Member Number: 914
I had mine replaced under the warranty about a year and a half ago they didnt even question me or anything.
steve 300c is offline
