06-11-2004, 01:43 PM
#3 (permalink)
Member Number: 85
Also, when you have set the mirrors where you like, move the selector switch to the middle. That way a bump on the switch will not do anything since that is the "locking" position.
You also should set your seat memory after setting the mirrors, then set your key fob for that memory position. Each time thereafter, all your memory settings will be put into place each time you enter the auto. Last radio setting before setting the memory will be locked onto your fob also.
Miles
