Old 10-15-2006, 06:09 AM   #1 (permalink)
PureEnjoyment's Avatar
Car: 2008 Chrysler 300C SRTdesign
Member Number: 6502
Send a message via AIM to PureEnjoyment
Unhappy Engine ping - knock NEED HELP
Hey guys,
I noticed yesterday night for the first time ever a really horrible pinging sound start coming from either my engine or another component in the front right area under the hood.
I was cruisin around last night when it just seemed to start all of a sudden. At the time of this drive I was running 93 octane with the 91 superchips tune. When it started to worry me I pulled into a gas station and immediately set my car back to stock (thinking it had something to do with the SC). However, the ping/knock still remains and I have no idea what the deal is. Checked my oil levels and they were fine too. It was late when I got home so I just went to bed and decided I'd look at it in the morning when the engine was cooled down, but it is still doing it prominently.
The noise gets faster and louder when I accelerate and press the pedal. Also, when I am cruising around and then just let the car coast the noise stops. As soon as I hit the pedal though the noise starts again. I can let it coast down to about 15mph until it starts to make the noise again on its own.
I have absolutely no idea what this means and would appreciate any input from anyone. I've never had a problem with the car in the past so I'm kinda worried what's up with it. I am currently uploading a video to maybe give some insight and let you guys here the sound....hopefully it sounds clear enough to bring some more light to my situation. I will post link as soon as it finishes.
Thanks again to anyone who can give me some advice.
-Joe
EDIT: VIDEO LINK ---> http://www.youtube.com/watch?v=AVSxJTCsbUQ
PureEnjoyment is offline
Old 10-15-2006, 06:28 AM   #2 (permalink)
Car: 2006 SRT 300C
Member Number: 4738
whose supercharger are you running
Whose supercharger kit did you use, actually more importantly did you change the heads when you did the supercharger? Are you blowing any smoke on startup? These were signs that I had when I dropped a valve guide.
If it is not a mechanical noise then does it ping at all engine speeds. Usually pigging will occur under acceleration (engine loaded). If it is always then maybe bad gas or weak fuel pump. if under load then richen up your aux injectors.
Just some minor ideas, good luck
Originally Posted by PureEnjoyment
Hey guys,
-Joe
srt-hardware is offline
Old 10-15-2006, 06:35 AM   #3 (permalink)
Member Number: 6502
I do not have a supercharger, but thanks for your information. It only pings like that at idle or when I am accelerating.
Old 10-15-2006, 09:16 AM   #4 (permalink)
mexi's Avatar
Car: 06 Chrysler 300c
Member Number: 3761
Send a message via AIM to mexi
sounds like a lifter tap to me...extreme tap...why its happening i dunno..ill ask my friend the is a 5star tech...later this week...hope you get right
300c loaded,nav, ves
mods.. FRANKRACING HEADS + SIDEWINDER cam
22's TIS 07'S
dub grill
clear corners
tinted tails
custom catback
JBA shorties and mid pipes
AFE stage II, billet tech catch can.
Diablo tune
motorad 4128 t stat ....best track time 12.7 @109
mexi is online now
Old 10-15-2006, 10:31 AM   #5 (permalink)
Member Number: 6502
Hey thank you I would appreciate that. Is that something that can be replaced?....(sorry I am a novice and know absolutely nothing about engines ). Thanks!
Old 10-15-2006, 10:35 AM   #6 (permalink)
mexi's Avatar
Member Number: 3761
i believe so but i think its major surgery...plus side is if thats what it is now would be a good time to upgrade cams and lifters...lol.. email me the clip and ill forward it to him....rcscott81@yahoo.com...
mexi is online now
Old 10-15-2006, 10:53 AM   #7 (permalink)
crhemi's Avatar
Car: 2006 Chrysler 300C SRT
Member Number: 3307
Somethings loose, does sound like a lifter.
crhemi is offline
Old 10-15-2006, 11:36 AM   #8 (permalink)
kevenj's Avatar
Member Number: 3126
That's not a "pinging" sound related to fuel grade. It does sound like a lifter but it could also very easily be an exhaust leak. It's often hard to tell those 2 sounds apart. Also you mention you can't hear the noise when you are just cruising, only under load. That says "exhaust leak" to me.
I would check to make sure the nuts that attach the exhaust pipe to the manifold are tight, and also look to see if you have a cracked exhaust manifold. This should not happen in a car this new, BUT if you washed the engine compartment when the engine was hot the cold water could cause a hot manifold to crack. IF it's not somthing simple like loose exhaust nuts then set the tune back to stock, and get it to the dealer asap and have it fixed under warranty. Don't drive it like that because if it's something in the valve train you could cause further damage. Oh and leave the stock tune installed for now and don't leave the flashpaq in the car, or mention it to the dealer.
kevenj is offline
Old 10-16-2006, 05:33 PM   #9 (permalink)
Member Number: 6502
Update
Hey guys thanks again for the input. I took my car in this morning and got a call from the dealership saying that it was a lifter problem and that they were gonna take it apart today or tomorrow and repair the problem.
My next question.....is this a rare occurence? I mean by no means do I rag on my car nor have I ever even put the wear and tear of taking it to a track. It seems like there's no way in hell something like that should happen after only 18k miles. Was that a factory defect? Is there anything I should be concerned about once they "fix" it and I get my car back?
Thanks again fellas!
-Joe
Old 10-16-2006, 07:04 PM   #10 (permalink)
mexi's Avatar
Member Number: 3761
no problem....but to answer you question...they dont make them perfect...lol
good news anyway
mexi is online now
