Help! Violent Shakes & Check Engine Light! - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Register Home Forum Active Topics (T) Gallery Insurance Garage Search Today's Posts Mark Forums Read
Old 10-04-2007, 10:12 PM   #1 (permalink)
Points: 3,764, Level: 1 Points: 3,764, Level: 1 Points: 3,764, Level: 1
ABSOLUTNATI's Avatar
Member Number: 12325
The other day I was driving on side roads. Coming to a stop, I noticed the car shaking pretty hard. It wasn't the road nor your typical Hemi idle. So I went onto the highway, and it started to do it again. I thought the enngine was going to die in the middle of the road! The check engine light came on. It was blinking and beeping, and finally stayed on. I had Roadside Assistance tow it to Chrysler. I have just recently had the tune-up and oil changed (New Spark Plugs etc.). They removed the spark plugs and cleaned them. Supposedly they had debris or carbon on them. Got the car back tonight and everything was good for the first 40 miles. HAPPENED AGAIN! After I turned the car off and restarted it, no more check engine light. I drove it around for an hour, couldn't get it to do it again. I'm at 35,650 miles! Go figure.
I do have the MAXCARE extended warranty also, so I'm not that worried. Also I noticed that the oil pressure goes from 15 PSI, up to 50 PSI when driving. Is that normal? I guess I'll take it in again. I should have roadside assistance pick it up again on their tab.
05 MAGNESIUM PEARL 300C
TWO 12" KICKER 07CVR124
AUDIOBAHN A1300HCT 1300W MONO
ENCLOSURE FROM ZENCLOSURES
WINDOW TINT
DARK SLATE FLOOR MATS
E & G STAINLESS STEEL FRONT TAG MOUNT
6000K HID BULBS
ABSOLUTNATI is offline
Old 10-05-2007, 10:12 AM   #2 (permalink)
Points: 12,345, Level: 1 Points: 12,345, Level: 1 Points: 12,345, Level: 1
jcsganga34's Avatar
Car: 2005 C 300
Member Number: 339
Send a message via AIM to jcsganga34 Send a message via Yahoo to jcsganga34
Water in the gas tank...or bad gas? Have you recently changed where you purchase your fuel? If the check engine light came on, it probably through a code, check this thread to see if it did and what it refers to.
Diagnostic Trouble Codes List & How to Access Codes In EVIC
jcsganga34 is offline
Old 10-05-2007, 10:36 AM   #3 (permalink)
Interesting. Right before this, I had taken the car in for a check engine light without the shaking. They had told me my gas cap was loose. I had also found that my gas cap was loose on the fillup before that. I wonder if someone has put something in my gas tank??!!!
Old 10-05-2007, 10:46 AM   #4 (permalink)
Points: 1,169, Level: 1 Points: 1,169, Level: 1 Points: 1,169, Level: 1
spoon7871's Avatar
Car: 2006/2007 Chrysler/Dodge 300SRT8/Plum Charger
Member Number: 8540
They might be taking your gas and replacing with something.
spoon7871 is offline
Old 10-05-2007, 11:25 AM   #5 (permalink)
Huh? Maybe, because my fuel level was the same. I remember looking at it because it was on full.
Old 10-05-2007, 11:48 AM   #6 (permalink)
We'll see what the dealer comes up with. I don't want to suggest something and have it void my warranty coverage on this particular problem. If someone were to take my gas, why in the world would they put something in it to replace it. My building has a 24 hour security guard in the lobby who can pretty much see all of the parking lot at night.
Old 10-08-2007, 02:16 PM   #7 (permalink)
Nothing found by the dealer yet. They said they had to call the Chrysler Tech's. I asked them if they checked the fuel system.
Old 10-10-2007, 07:25 PM   #8 (permalink)
Points: 853, Level: 1 Points: 853, Level: 1 Points: 853, Level: 1
Car: 2005 Chrylser 300C
Member Number: 10714
Mine did the same...turned out to be the valve springs broken of cyl 7 and 8....but mine would not run at low rpm....it would die.
Changed under warranty
CANHEMI is offline
Old 10-11-2007, 09:48 AM   #9 (permalink)
Well, found nothing . Got it back and hasn't done it again. maybe it was left over residue from when they cleaned the spark plugs when it happened dramatically at first.
Now I'll take it back for the squeeking coming from the backseat over bumps. By the way, 200 miles till 36k.
Old 10-11-2007, 11:36 AM   #10 (permalink)
Points: 2,096, Level: 1 Points: 2,096, Level: 1 Points: 2,096, Level: 1
erik5032's Avatar
Member Number: 12558
I was siphoned once with my 300 and now i have a locking gas cap which to my surprise actually stopped siphoning... They filled my gas tank up with water (thank God i noticed that something was wrong before i started or moved my car.) I just felt like somthing was wrong almost like a sexth sense. My car does talk to me thank God for our ESP (extra sensory perception lol)
Mods:
[x] De-Molded
[x] De-Emblemed
[x] 35% tint on all
[] Air Hammer
[] Flat Black Paintjob (summer of '08)
[] Flat Black paintjob on stock rims (summer of '08)
[] Brushed Metal accents (replacing all chrome)
A wise man gets more use from his enemies than a fool from his friends.
erik5032 is offline
Check engine light came on kobe8 General Discussion on Issues / Trouble Shooting 20 01-24-2012 05:44 PM
Check engine light & mileage mariogreymist General Discussion on Issues / Trouble Shooting 21 01-02-2008 09:10 PM
B&G Can Turn Off The Long Tube Header "Check Engine" Light! tbyrne SRT8-Specific Performance & Engine/Intake/Exhaust Mods 3 07-22-2007 05:08 PM
Check Engine Light On Globalexcuse General Discussion on Issues / Trouble Shooting 5 11-10-2006 12:00 PM
Check engine light (or is it brake light) pops up randomly.... thomas300ltd Problems / Dealer Service 3 07-11-2006 05:26 PM
