Old 10-17-2007, 05:05 PM   #1 (permalink)
slack-axe
slack-axe's Avatar
Car: 2007 Chrysler 300C
Member Number: 4312
possible issue with low RPMs at idle
I have an '07 300C with approximately 4200 miles on the clock -- all stock except for a Mopar drop-in filter. I have noticed the idle speed from EVIC shows around 520-530rpm, and other times it hovers around 600-620.
Thankfully there have been no stumbles when it gets down to the low 500's, but I'm concerned that might be a little low. From doing searches on the Forums, I see that the RPMs at idle for the 5.7 have a pretty broad range (from 500rpm to 650rpm).
Should I be concerned about it dropping into the low 500rpm range? I use Shell 89 octane consistently, and there have been no issues with performance.
Thanks in advance,
Phil C.
2007 300C
Predator / 180 Tstat / Mopar drop-in filter
2006 Charger R/T with R&T
Predator / 180 TStat / Mopar drop-in filter
slack-axe is offline
Old 10-20-2007, 08:21 PM   #2 (permalink)
slack-axe
slack-axe's Avatar
Member Number: 4312
Dealership Update
Took the car to the dealer today, and without beating myself up too badly, its safe to say that Hemi Knowledge > me
My wife's Charger R/T has the same RPM at idle when hot and A/C not running (and in Drive). At the Dealership, the Tech hooked up the Scantool and could find no codes stored, and said everything checked out ok. Then, the Service Manager and I logged a few miles in the 'C' making sure I was satisfied with their findings.
I honestly think they loaded some Hemi mojo into the C today....I took it out and ripped off a few sub 6 second 0-60 times tonight. And when I did my last run, I yanked the time below out of my butt.....I'll probably never duplicate it again.....but it brought a big ole' grin to my face.
Conditions were: Temp 65F, Level road, 1/4 tank of gas, stick mode, ESP off. The only "mod" I have at the present time is a Mopar drop-in filter.
Old 10-21-2007, 09:10 AM   #3 (permalink)
SMosher
SMosher's Avatar
Member Number: 14217
how are we getting this timer on the evic from a C?
SMosher is offline
Old 10-21-2007, 10:21 AM   #4 (permalink)
Moose
Moose's Avatar
Car: 2006 SRT-8 6.1 Hemi 300c
Member Number: 4390
The 5.7's are a smooth low idle and that is a common number. The low idle is also for fuel saving while idling in traffic and at lights etc. You're fine.
Moose Burnout here
Highest trap 120 MPH
Fastest reaction time 0.00
Mod list:
Secret Moose Diablo tune
Magnaflow high flow cats
TNT dual nozzle
Corsa cat back
GSM fan mod
180 tstat
Back to Back Calendar Winner
Moose is offline
Old 10-21-2007, 10:26 AM   #5 (permalink)
slack-axe
slack-axe's Avatar
Member Number: 4312
Thanks much for the info Moose!
Old 10-21-2007, 10:30 AM   #6 (permalink)
Moose
Moose's Avatar
Member Number: 4390
Hey, no problem Slack. I am a 5.7 lover! I have owned two of them now and they are the smoothest most snappy when you need them motors. Right now I've got a 5.7 non MDS in my garage.
Moose is offline
