Old 10-22-2007, 08:17 PM   #1 (permalink)
CANHEMI
Car: 2005 Chrylser 300C
Member Number: 10714
Solution for stumble/hesitation at accel/low rpm.....
Ok, So after months of diagnostics....and changing plugs (twice), O2 sensors, 3 EGR valves, 1 PCV, throttle body clean, 1 coil....the dealer was able to find the reason for the hesitation at low acceleration, typically at 2200 rpm. The car would give a feel of missfire, stumble........THE REASON WAS THE GAS PEDAL. The voltage sender on the gas pedal was not sending the correct voltage (or resistance) to the unit in the trunk (receiver unit).
Have your dealer check that before you spend any money......and change the pedal assembly.OOuuuuuuuuuuuf finally resolved.
CANHEMI is offline
Old 10-22-2007, 10:17 PM   #2 (permalink)
bruno's Avatar
Member Number: 3129
That news sure is something else! Sorry to hear you went through so much before some troubleshooting paid off. Your message should definitely help out others who might be experiencing the same issue.
bruno is offline
Old 10-22-2007, 10:25 PM   #3 (permalink)
doodie300c
doodie300c's Avatar
Car: 2005 Chrysler 300c
Member Number: 1713
wow it took them all that time to figure that out. im sure if you would of mentioned that, they would of looked at you like you were crazy...
doodie300c is offline
Old 10-22-2007, 10:51 PM   #4 (permalink)
joey
Member Number: 232
Congratulations on your persistent and getting your car fixed
joey is offline
Old 10-23-2007, 09:48 AM   #5 (permalink)
BruceBanner
BruceBanner's Avatar
Car: 2006 Chrysler 300
Member Number: 6683
i have taht same problem, did your engine light ever come on? mine was coming on and off for a while, but it has been on for the last full day
BruceBanner is offline
Old 10-26-2007, 03:45 PM   #6 (permalink)
CANHEMI
It has been a few days...and all is well. So I am sure that was the problem.
Bruce, my check engine did not come on.
If you have a check engine, then the CPU has noticed a fault...they should be able to pin point what it is.
The had a check engine on the car before but it totally died and it ended up being broken valve springs for cyl 7&8. big mess too.
CANHEMI is offline
Old 10-30-2007, 06:21 PM   #7 (permalink)
ABSOLUTNATI
ABSOLUTNATI's Avatar
Member Number: 12325
Hey BruceBanner and CANHEMI, see if my thread sounds like what is happening to you!!!
Help! Violent Shakes & Check Engine Light!
05 MAGNESIUM PEARL 300C
TWO 12" KICKER 07CVR124
AUDIOBAHN A1300HCT 1300W MONO
ENCLOSURE FROM ZENCLOSURES
WINDOW TINT
DARK SLATE FLOOR MATS
E & G STAINLESS STEEL FRONT TAG MOUNT
6000K HID BULBS
ABSOLUTNATI is offline
