Old 12-13-2007, 07:37 PM   #1 (permalink)
Adam Control
Adam Control's Avatar
Car: 2007 Chrysler 300C SRT-8 - Fully Loaded!
Member Number: 13446
Send a message via AIM to Adam Control
Auto Windows act wierd?
My auto windows act wierd sometimes.
Sometimes they won't go down (auto) without me holding the button but sometimes they do. Sometimes it's the driver's side that won't work and sometimes it's the passengers. Not really at the same time. Also, when I heit them up, sometimes the window goes halfway up then back down.
Wierd, huh?
Any clues?
. b o r n o n 8 - 4 - 0 7 . s u r g e r y i n p r o g r e s s .
Adam Control is offline
Old 12-13-2007, 07:49 PM   #2 (permalink)
Rambit
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
Have a look at this TSB. It sounds like a fix for the problem you seem to be having and involves replacing the door modules.
http://www.wkjeeps.com/misc/LX/TSB/TSB_0801107a.pdf
Bernie
Rambit is online now
Old 12-14-2007, 10:27 AM   #3 (permalink)
Casey
Casey's Avatar
Car: 2007 Chrysler 300C SRT8
Member Number: 11732
my drivers side does the same thing, oddly enough its always when im getting gas, never at a drive thru or something like that, so im thinking it has to do something with the car being shut off and back on.
i just go thru the reset procedure, which is something like raise the window all the way manually (no one touch), then lower manually all the way, and then raise again. generally that works out. i havent acted on that TSB that rambit brought up tho.
Casey is online now
Old 12-14-2007, 10:32 AM   #4 (permalink)
Adam Control
Hmmmm...I really appreciate the input! I'm gonna print out that TSB and take it to a dealer and see where that takes me.
Old 12-15-2007, 10:10 AM   #5 (permalink)
McLovin300C
Car: 2007 Inferno Red Chrysler 300C SRT8
Member Number: 15719
This has happened to me as well.
I put the window all the way up then press down and held it for about 3-5 seconds then immedialty pull up on the swithc and it should work.
McLovin300C is offline
Old 12-15-2007, 01:16 PM   #6 (permalink)
300CSTL
300CSTL's Avatar
Car: 2006 Chrysler 300C Heritage DUB
Member Number: 14839
This is exactly what to do most of time to fix this. I have learned the problem relates to "improper" holding down of the switch at some point in time which deprograms the auto up and/or auto down. reprogramming and being careful while using it in the future is usually all that is necessary. in a pertect world, the "unlearning" would not be accomplished so easily without your intending to do it.
Les in STL, MO
2006 300C Heritage/DUB edition
http://www.pbase.com/lessteinberg/300c_dub_edition
“Life is not a journey to the grave with intentions of arriving safely in a pretty well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out and loudly proclaiming ... WOW! What a ride!”
300CSTL is offline
Old 12-15-2007, 03:26 PM   #7 (permalink)
thetaxman
Member Number: 7658
Mine does that all the time, just have to do the reset procedure. Auto seat back and wheel up at exit do the same thing too, seem to have a mind of their own. Odd thing is all 3 never stop working at once, it is usually just one of the features. Of course complain to the dealer and they say everything is working fine so my guess is they pull a fuse or something to reset it.
thetaxman is offline
Old 12-15-2007, 03:37 PM   #8 (permalink)
Rambit
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
What some of you guys are doing is simply performing the battery reconnect procedure. If this is a persistant problem like some of you are having, the TSB issue is more likely your problem and the modules are at fault.
Bernie
Old 12-15-2007, 04:19 PM   #9 (permalink)
Adam Control
Yeah, I'm calling the dealer on Monday. I did the reset and it's fine but I feel there might be a problem. I would never have thought I would have to "be more carefull" when pressing a window button. It's not like I punch it with my fist when I wanna open the window!
Old 02-04-2008, 11:39 AM   #10 (permalink)
peteg825
Member Number: 16206
I just bought my 05 300c 3 weeks ago and all of a sudden I had this problem. My auto down worked but not my auto up on the drivers side window. I did a search and found this thread, I did the reset and sure enough it works now. Thanks, this site rocks.
peteg825 is offline
