Old 01-06-2008, 06:36 PM   #1 (permalink)
1badv
Car: 2006 Chrysler 300C NAV & DVD
Member Number: 15115
Incorrect fuses listed
The following information maybe limited to 2006 300c's built and sold in Canada with a "First Edition" owners manual.
As some of you are probabaly aware the owner's manual contains a number of fuse size errors when comparing it to what your car has installed in it from the factory. Additionally, the owner's manual fuse sizes dont match up exactly to what is printed in the 2006 service manual. You may also have noticed the vehicle has some fuses installed in some locations that both the owner's manual and service manual say are blank.
Here's my list of fuse errors;
1. Front PDC - cavity #5 - my car has a 20a installed when owner's and service manual say it should be a 25a
2. Front PDC - cavity #12 - my car has a 5a installed when owner's and service manual say it should be blank
3. Front PDC - cavity 14 - my car has a 25a installed when the owner's manual says 20a and service manual says 25a
4. Front PDC - cavity 15 - my car has a 20a installed when the owner's manual says 25a and the service manual says 20a
5. Front PDC - cavity #16 - my car has a 15a installed when the owner's manual says 20a and the service manual says 15a
6. Front PDC - cavity #24 - my car has a 60a installed when owner's and service manual say it should be blank
I haven't finished checking the rear yet but have already found some errors and will post them soon.
Speaking as an automotive forensic investigator, I find these errors to be serious enough to inform Transport Canada. NHTSA has recalled vehicles that have had the wrong tire pressures or axle weight ratings listed on a sticker and these errors, if wide spread, are as at least as serious. This is where forum members can helpout, please check your manuals and your vehicles to see if the two match.
BTW - my 2006 300C has had absolutely no problems of any kind, has 17K kms on it, and has NAV, DVD, sunroof and almost every other 06 option except AWD
Hope this helps out some members since you could be trying to troubleshoot a system then think someone has goofed around with it (because of the wrong rating on the fuse) when in fact they have not. Whatever the case, whether the factory installed a late change or the service manual is correct or the owner's manual is correct I/we need to know.
1badv is offline
Old 01-06-2008, 07:00 PM   #2 (permalink)
Rambit
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
Well, I don't quite know what to say here, but here's a pic taken from a 2006 300C. I was used to demonstrate where fuse 11 was located in the front PDC. Maybe you can compare yours to this one. Strange that no one has ever come upon this in 4 years now.
Bernie
Rambit is offline
Old 01-06-2008, 07:29 PM   #3 (permalink)
Rambit
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
I've just gone throught the service manual and I can confirm your findings. I'm wondering if some of those locations that call for blanks are actually spare fuses. I would also think these units come with pre installed fuses from the company that produces the PDC's and all BAP does is bolt them in.
Bernie
Rambit is offline
Old 01-06-2008, 07:47 PM   #4 (permalink)
1badv
Bernie
Your fuses #14 and #15 - are different then mine - #14 is 25a but says 20a in om and 25a in sm, your #15 a 25a but says 25a in om and 20a in sm. Also your fuse #16 is missing and should be a 20 (om) or 15 (sm) but I assume you took it out since it is listed as the Powertrain Control Module fuse. Whats' the big 60a fuse for? - both manuals say blank - I haven't pulled it yet to see what it feeds. Have you?
1badv is offline
Old 01-06-2008, 08:03 PM   #5 (permalink)
Rambit
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
That wasn't my picture, but it is from the same car as yours (06 300C). I can't even remember who it belongs to other than it was posted some time ago demonstrating where fuse 11 is. I have no idea what the 60 amp fuse is for sorry.
Most of us pull fuse 11 for 15 seconds to get rid of the adaptive learning when our cars start behaving like granny goodwitch. You should try it when you feel your car is becoming sluggish and bogs down, then drive it around with a great deal of "spirit"!!! Performance and crisper shifting will result, but unfortunately if you do a lot of city stop & go it relearns quite fast.
Bernie
Rambit is offline
