Old 01-10-2008, 06:49 PM   #1 (permalink)
dpatt67
Car: 2005 C 300
Member Number: 4216
ck engine light code for t-stat or engine temp sensor
I was wondering if any of you had the check engine light come on and it read the code for : low coolant level
bad thermostat
engine temp sensor bad
My wife was driving home from work and it came on. I checked the coolant and it was fine. Should i replace the thermostat first or try and replace both it and the sensor? Thanks.
dpatt67 is offline
Old 01-10-2008, 07:45 PM   #2 (permalink)
Rambit
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
Do you happen to remember what the code was, or was it just a warning in your EVIC?
Bernie
Rambit is offline
Old 01-10-2008, 07:51 PM   #3 (permalink)
Moose
Moose's Avatar
Car: 2006 SRT-8 6.1 Hemi 300c
Member Number: 4390
Trader Rating: (4)
Do you have an aftermarket lower temp tstat? If not i'd take it in under warranty. If you are out of warranty I'd clear the code and keep my eye on her. Oh, and also post the code like Rambit said.
Moose Burnout here
Highest trap 120 MPH
Fastest reaction time 0.00
Mod list:
Secret Moose Diablo tune
Magnaflow high flow cats
TNT dual nozzle
Corsa cat back
GSM fan mod
180 tstat
Back to Back Calendar Winner
Moose is offline
Old 01-10-2008, 07:59 PM   #4 (permalink)
Rambit
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
I've been doing some pliminary checking and see this condition may come up if idling for long periods in traffic for starters and if that turns out to be the case here it's a temporary thing with no fix needed. We still need more info though!
Bernie
Rambit is offline
Old 01-10-2008, 08:23 PM   #5 (permalink)
dpatt67
Car: 2005 C 300
Member Number: 4216
Actually, i just took it to the auto parts store for them to read, and the paper they gave me showed no code #, just what the pcm is telling the machine. Here is what the paper says:
"The pcm has determined that the input from the coolant temperature sensor indicates a temperature value that is below the thermostat regulating temperature".
Definition: coolant temperature is always low.
Explanation: The pcm verifies that the engine is at a proper operating temperature.
Probable causes: -check coolant level
-thermostat defective
-engine temperature sensor defective
That it. How can i erase the codes to see if it comes up again? BTW, the t-stat is stock. Thanks again!
dpatt67 is offline
