P0520 Code Engine Oil Pressure Sensor/Switch Circuit Malfunction - Page 5 - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 05-31-2012, 11:55 PM   #41 (permalink)
Points: 1,405, Level: 1 Points: 1,405, Level: 1 Points: 1,405, Level: 1
Member Number: 31206
I have the P0520 code. I also have a slight coolant leak, I think from the thermostat housing. Looking at some of the pictures, the pressure switch/sensor looks to be very close to where my leak is. I wonder if maybe the connector is just contaminated? And if it is possible to unhook the connector to clean it without doing the whole alternator removal thing?
GordonFreeman is offline
Old 06-01-2012, 07:26 AM   #42 (permalink)
Points: 8,771, Level: 1 Points: 8,771, Level: 1 Points: 8,771, Level: 1
5CH_omar's Avatar
Member Number: 22798
I would just replace it with a new one. There are not really critical to change immediatly. I only took me 40min to do the whole process which included cleaning the mating part that attaches to the sensor with compressed air and contact cleaner. I think it would take you longer trying to work around the alternator but hey its your time not mine.
BTW. It probably is your themostat housing thats leaking because I had to have mine replaced to when i did a flush and refill.
**Make sure you use a 8 point socket. Since the sensor has rounds a 16 is likely to slip an get stuck. I happend to me the second time i changed it.
5CH_omar is offline
Old 06-01-2012, 05:08 PM   #43 (permalink)
Local Chrysler dealer had one in stock. Busted knuckles here we come!!
Old 06-22-2012, 11:18 PM   #44 (permalink)
Well, I went to give this a shot today, didn't get past the top alternator bolt (I didn't try real hard), so I looked underneath and was not feeling up to trying to get those out either. I think I might give it a shot again and just remove the belt and go in from the front.
Also read on one of these threads that this code may make the MDS not work resulting in worse mileage, which I'm getting.
"My magnets are better than your windows." - Me
Old 06-23-2012, 07:30 AM   #45 (permalink)
5CH_omar's Avatar
I always have a cheater pipe hand. Trust me your going to need it. I would unloosen the top on first then go under the car and remove the 2 bolts. Then go back up and remove the bolt you loosened. Make sure you do this in the day time youll need the light. I had a hell of a time with the sensor clip I broke it.
5CH_omar is offline
Old 06-23-2012, 07:31 AM   #46 (permalink)
5CH_omar's Avatar
It seems a PIA but i really is easy. Should take you thirty min
5CH_omar is offline
Old 06-24-2012, 07:30 PM   #47 (permalink)
Got it done, from the top. The tricky part is working with a mirror to get the red tab unlocked. Was cake the rest of the way.
Code has not reappeared and it seems to be getting 2-3 MPG better.
Old 06-26-2012, 08:38 AM   #48 (permalink)
Points: 14,338, Level: 1 Points: 14,338, Level: 1 Points: 14,338, Level: 1
customaudioman's Avatar
Car: 2005 chrysler 300c
Member Number: 22271
I get the same code, mpg is off by 2-3 miles. I dont hear the MSD kick on anymore which I used to hear while cursing. could this be a bad switch sensor? If so how much are they?
customaudioman is offline
Old 06-26-2012, 12:06 PM   #49 (permalink)
Probably. $57.50 from the dealer.
Main tools needed to do it from the front:
3/8 ratchet (for tensioner)
flat screw driver to slide the red tab on the connector
mirror (remote video would kick butt)
needle vice grip (to press the other connector lock and pull the connector)
1 -1/16 deep socket, 3" extension, ratchet
some contact cleaner to clean the connector on the harness
Old 07-29-2012, 10:29 AM   #50 (permalink)
Points: 71, Level: 1 Points: 71, Level: 1 Points: 71, Level: 1
Car: 2005 Chrysler 300C SRT8
Member Number: 39622
I Got Code P0523(Engine Oil Pressure Sensor/Switch Circuit High Voltage)...... Is this the same sensor for Codes P0520 & P0522 ??
UA Steamfitter is offline
Malfunction - Oil pressure sensor Macca Australia Forum 11 03-13-2011 06:12 PM
P0325 Knock Sensor 1 Circuit ( Bank 1 ) Code Theteese Problems / Dealer Service 7 03-11-2010 06:35 AM
Code P0520(Engine Oil Sensor) How long can I get away with this ojmcneill General Discussion 5 12-03-2009 08:43 PM
P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem raspyvette Problems / Dealer Service 2 05-30-2009 07:23 PM
ck engine light code for t-stat or engine temp sensor dpatt67 Problems / Dealer Service 4 01-10-2008 09:23 PM
