Problem With Remote Entry Key Fob? - Page 2 - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 05-06-2009, 08:21 AM   #11 (permalink)
Activity: 65% Activity: 65% Activity: 65%
bruno's Avatar
Member Number: 3129
My repair was free! Those cheap clips were all broken in both my keys thus disabling my remote lock/unlock feature.
One of my CenCalLX club members simply opened up them up, put some paper inside to put pressure over the batteries and both fobs work like they are brand new!
bruno is offline
Old 08-01-2009, 01:45 PM   #12 (permalink)
Points: 3,431, Level: 1 Points: 3,431, Level: 1 Points: 3,431, Level: 1
Member Number: 17165
I had my '05 300C for 18 months now, one remote never worked. After dropping the one i use for the last time it stopped working. i opened it up, and saw the bad solder joints. i soldered 2 on this remote, then opened the other remote and saw that it had the same problem. After soldering both, i tried them, but no luck. i put the batteries on the voltmeter, and they were both dead. it looks like they shorted out when the clip shifted when the solder lugs broke. After getting 2 new batteries, (3 pack for $11 at radio shack) they both work fine. So be sure to check the batteries after you fix the solder problem.
Joe from N.Y. is offline
Old 10-01-2009, 01:56 PM   #13 (permalink)
Points: 1,695, Level: 1 Points: 1,695, Level: 1 Points: 1,695, Level: 1
Car: 2006 Chrysler 300 Base
Member Number: 21139
Mine was in terrible shape and I just decided to replace as my FOB was in kind of poor shape to begin with, so just an FYI, OEM FOB is pretty reasonable on transponder island, had it for $80.
enjoyincubus365 is offline
Old 10-20-2009, 02:31 PM   #14 (permalink)
Points: 226, Level: 1 Points: 226, Level: 1 Points: 226, Level: 1
Car: 2005 CHRYSLER 300C
Member Number: 24231
key fob
I just recently had the same problem with my RKE battery so I sodered it back together and it still didnt unlock the door. So I unlocked it manualy open the door alarm went off I just put the key in the ignition and turned the car on now it works great. Hope this helps....
RALPH MARTINEZ is offline
Old 02-16-2010, 06:57 PM   #15 (permalink)
Points: 9,106, Level: 1 Points: 9,106, Level: 1 Points: 9,106, Level: 1
Car: 2005 Black 300c
Member Number: 130
Finally had to fix my broken keys. Tired of the alarm going off when I open the door.
Cut a piece of copper wire and shaped it like the battery bracket. Then soldiered the copper into the two holes in the circuit board. Next soldiered the stainless steel bracket back onto the base against the copper wire. Put everything back together with a piece of pressure foam on top of the battery bracket to hold / pressure everything together.
300c Owner is offline
Old 04-18-2010, 12:01 PM   #16 (permalink)
Points: 647, Level: 1 Points: 647, Level: 1 Points: 647, Level: 1
Member Number: 26414
Send a message via Skype™ to Razk
Thanks so much perfect quick tip solved my problem took about 2min and it all works like a charm
Razk is offline
Old 11-27-2010, 06:33 AM   #17 (permalink)
Points: 2,653, Level: 1 Points: 2,653, Level: 1 Points: 2,653, Level: 1
300onDueces's Avatar
Car: '05 Chrysler 300C-AWD
Member Number: 3063
Desiree, both of my key fobs broke in just the way you described. I resoldered the cold joints and they both work like a champ now. Thanks a million.
2011 Dodge Challenger SRT 392 6-spd
2007 GMC Yukon Denali XL
2005 300C-AWD
1964 Chevy Impala SS
1999 Yamaha R1
USAF
300onDueces is offline
Old 11-27-2010, 07:09 AM   #18 (permalink)
Points: 34,446, Level: 1 Points: 34,446, Level: 1 Points: 34,446, Level: 1
Member Number: 1483
You are welcome!
DESIREE is offline
Old 10-24-2011, 07:16 PM   #19 (permalink)
Points: 31, Level: 1 Points: 31, Level: 1 Points: 31, Level: 1
Car: 2005 chrysler 300c
Member Number: 35196
DESIREE
Thanks so much for the detailed description. I was able to solder one of my remotes
and get it working OK. The other appears to have the same problem.
A great post - thanks again!
Jim
jimbobcar is offline
Old 01-14-2013, 09:08 AM   #20 (permalink)
Points: 2,246, Level: 1 Points: 2,246, Level: 1 Points: 2,246, Level: 1
Member Number: 19850
I have soldered mine at least twice and still cant get them to work. Will try replacing the batteries again. As for new ones, I saw one post about a replacement. I also saw a replacement key that required both original keys to work in order to program the new one. Otherwise, you would need to go to a locksmith or Chrysler to do it. Is this true?
Kurgen is offline
Intermittant remote/key fob unlock problems coryj Car Audio/Alarms/UConnect/Navigation 9 07-04-2012 02:43 PM
Did someone try to retrofit the regular key with the integrated key fob? toshik Car Audio/Alarms/UConnect/Navigation 0 10-14-2009 05:19 PM
Integrated Key and FOB LeeSoFL General Discussion 10 03-30-2006 03:01 PM
Problem with linking Remote Key RobertR Problems / Dealer Service 31 09-25-2004 09:24 PM
