Help!!!car is locked down and won't start. - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 21 (permalink) Old 01-20-2008, 04:56 PM Thread Starter
Points: 4,704, Level: 1 Points: 4,704, Level: 1 Points: 4,704, Level: 1
myrtle300c's Avatar
I disconnected the batterey to try and fix a window issue as suggested by a user in another thread. I hooked it back up and went to get in the car and it would only start for about 3 seconds and shut off. there is also a little red light blinking. It is the only light in the owners manual cluster illustration that does not have a description. it is under the fuel and speed gauges and the mph needle points right at it when at rest. Anyway after a few tries, the car no longer starts at all. I suspect this has something to do with the alarm. The original keys do not work to unlock the doors or any other function that used to work remotely. I've tried leaving the ignition in the "on" position and also tried hit the lock buttons manually while in this mode. Even tried disconnecting- reconnecting the battery again. nothing seems to work. anyone please help...I want to get out and watch football......
"Our answer must consist not in talk and medication, but in right action and right conduct" Victor Frankl
CV every option but cold weather
myrtle300c is offline
post #2 of 21 (permalink) Old 01-20-2008, 05:09 PM
Points: 76,531, Level: 1 Points: 76,531, Level: 1 Points: 76,531, Level: 1
moddog's Avatar
Car: 2005 Build Date 08/24/04 Custom engine cover SS Hood cover SS E&G Grill Chrysler 300C
That happen to me and it was the anti-theft system that went crazy. They had to replace mine maybe yours needs to be reset.
Stock 312.75 rwhp 359 rwt
Front & Rear SRT Fascia,Hotchkis Sway Bars,BT catch can,power steering cover,and others, Clear side markers.Leather console cover from 22 Elite and Racing peddles, 180 MotoRad stat,custom Engine cover with pin-striping,Corsa Cat Back,K&N Drop in filter,Diablo 91 Tune. 06 SRT8 seats custom all leather skins JBA High flow cats
PA MODERN MOPAR GROUP
moddog is offline
post #3 of 21 (permalink) Old 01-20-2008, 05:34 PM
Administrator
Points: 463,600, Level: 1 Points: 463,600, Level: 1 Points: 463,600, Level: 1
Rambit's Avatar
Car: 2005 300C SRT8
I'm not saying this is going to work, but it sure as hell can't hurt and frankly I just don't know. This is from a post by glhs837, dealing with pregramming a 3rd key. Just skip that part (#6).
1. Insert Key #1, turn to ON for 10 seconds
2. Key #1 OFF and remove
3. Within 5 seconds, insert Key #2 and turn to ON
4. Wait ten seconds, single chime sounds, Theft Alarm (red dot) starts flashing and remains til Step 7
5. Key #2 OFF and remove
6. Within 10 seconds, insert Key #3 turn to ON.
7. Wait 10 seconds, another single chime, Theft Alarm stops, then flash three times, then stop.
I'm really curious to see if this works. Might just help someone else some day.
Bernie
Headlights etc...
Rambit is offline
post #4 of 21 (permalink) Old 01-20-2008, 05:56 PM
Points: 2,066, Level: 1 Points: 2,066, Level: 1 Points: 2,066, Level: 1
Car: 2005 Chrysler 300c
Bernie
When you are adding a new key I think that key #1 has to already be programed. Im also curios to see what happens
Sunney is offline
post #5 of 21 (permalink) Old 01-20-2008, 06:09 PM Thread Starter
myrtle300c's Avatar
it didn't work....I called a locksmith because a friend told me they deal with these issues all the time. He told me to put the key in "on" position for 10 to twenty minutes and if that didn't work to call him back. it hasn't worked yet, but maybe if it sits a little longer...thanks for all the suggestions. I guess I'm stuck home alone for the game...sure was craving wings....
post #6 of 21 (permalink) Old 01-20-2008, 06:17 PM
Administrator
Rambit's Avatar
Car: 2005 300C SRT8
Sorry it didn't work, but make sure to keep us updated on this.
Bernie
Rambit is offline
post #7 of 21 (permalink) Old 01-20-2008, 06:56 PM
moddog's Avatar
When it happen to me I was out shopping. Used the remote to lock the car came back unlock the car started it as soon as I left the key go it shut off. I was across from the dealer wen over to them. The sent a guy over to look at it and told me they would have to order a new anti-theft system. Car was only 6 weeks old then so I would call your dealer on this one
moddog is offline
post #8 of 21 (permalink) Old 01-20-2008, 08:29 PM
why would disconecting the batery fix your window problem? its not like there computer controlled or anything like that, im 99% sure that they can reset the anti theft system it should be like an hour job at the dealer if they have to replace it im sure it will not be cheap. Im also having some problems with my window switches to, but only happens about once a month so i didnt even bother talking it to the dealer yet. Also check in the evic when the last vta trig was to confrim that it is the anti theft that is shutting your car off.
Sunney is offline
post #9 of 21 (permalink) Old 01-21-2008, 07:27 AM Thread Starter
myrtle300c's Avatar
vta trig = 0
post #10 of 21 (permalink) Old 01-21-2008, 07:38 AM Thread Starter
myrtle300c's Avatar
called two different dealers and got the same thing...the first four times I tried to start the car, it came on and shut down within a few seconds. if I had let it sit for an hour or two and unhooked the battery again, then I would be able to reset it myself. But when I turned it a fifth time, it put the car in a security mode that can only be reset by the dealer..so I have to have it towed in and reset....wish that disclaimer was somewhere inthe manual!!!
Locked Keys In Car/ Trick to Unlock? Quiknen Problems / Dealer Service 29 02-19-2014 03:45 PM
car locked down and won't start(see original) derick UK & Europe Regional Forum 2 01-21-2008 11:56 AM
Car won't start...I hate this car! Adam Control Problems / Dealer Service 28 12-28-2007 05:33 PM
PLEASE HELP! Car won't start kcshaner 1st Gen SRT8-Specific General Discussion 39 04-08-2007 01:50 PM
Car won't start! ChromeTailfins Problems / Dealer Service 9 03-15-2005 03:14 PM
