P0404 Exhaust Gas Recirculation Circuit Range/Performance - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 3 (permalink) Old 08-25-2008, 09:25 AM Thread Starter
Points: 16,506, Level: 1 Points: 16,506, Level: 1 Points: 16,506, Level: 1
Car: 2013 Chrysler 300S awd
Is there a way to fix it without going to the dealer
los24k is offline
post #2 of 3 (permalink) Old 08-25-2008, 08:30 PM
Elite Contributing Member
I wish I knew more about the EGR. But if you wanted to avoid the dealer at all cost, you might try replacing some of the major EGR components. They are not that expensive and they look easy to replace, such as the 1) EGR valve and 14) Solenoid.
But I really don't have a clue.
Here is info from the Service Manual for code PO404
Set Condition:
The EGR flow or valve movement is not what is expected.
Possible Causes
(F856) 5-VOLT SUPPLY CIRCUIT
(K35) EGR SOLENOID CONTROL CIRCUIT
(K900) SENSOR GROUND CIRCUIT
EGR SOLENOID ASSEMBLY
PCM
Direct PARTS connection
1) Egr valve 2) Egr valve Gasket 3) Egr tube
4) Egr tube Seal 5) Egr tube Gasket 6) Leak detect pump
7) Hose To leak detect pump 8) Filter 9) Filter hose
10) Vent hose 11) Vapor canister 12) Vapor canister Grommet
13) Vapor canister Bracket 14) Solenoid 15) Solenoid Bracket
16) Vacuum harness 17) Oxygen sensor Before catalyst 18) After catalyst After catalyst Right
joey is offline
post #3 of 3 (permalink) Old 08-26-2008, 03:00 PM Thread Starter
Thanks Joey...for the info, the strange thing is that I drove from florida to New jersey and when I filled up in florida..Gas tank was almost empty I put super 93 octane and the engine light went on after like 10 miles..I put plus 89 octane there after....and I have a 300c.I just pulled fuse 11 yesterday to erase engine light and I'm waiting to see if it goes back on.....again thanks for the info if it does go back on I;m going to replace the egr valve like you said thanks.
los24k is offline
P0403 Exhaust Gas Recirculation Circuit Malfunction IMPORTEDFROMDETROIT Problems / Dealer Service 14 03-02-2010 03:37 AM
P0403 Exhaust Gas Recirculation Circuit Malfunction mikey's300c Problems / Dealer Service 0 11-22-2009 10:01 PM
P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem raspyvette Problems / Dealer Service 2 05-30-2009 06:23 PM
Po406 Exhaust Gas Recirculation Sensor A Circuit High JOHNNYRENO Intake & Exhaust 3 08-12-2008 07:38 PM
Sluggish performance and 89 octane gas motrhed87 Performance General Discussion 30 01-18-2005 11:17 AM
Replace with
