Replaced egr valve... Now What - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 11-07-2008, 07:25 PM   #1 (permalink)
Points: 2,388, Level: 1 Points: 2,388, Level: 1 Points: 2,388, Level: 1
Member Number: 18656
Thumbs down Replaced egr valve... Now What
I had a p406 code so I replaced my egr valve today and after completing I drove for a while and my ETC (electronic Throttle control) light came on and it idled high. I reset the light just like the manual says. NOW I checked the codes on the EVIC system and have a p2173 code. What did I do wrong? What am I missing?
myfirstgixxer600 is offline
Old 11-07-2008, 09:18 PM   #2 (permalink)
Elite Contributing Member
Member Number: 232
The Service Manual says the most likely cause of P2173 is a vacuum leak.
A large vacuum leak is most likely the cause of this DTC.
Inspect the Intake Manifold and Throttle body for leaks and cracks.
Inspect the Power Brake Booster for any vacuum leaks.
Inspect the PCV system for proper operation or any vacuum leaks.
Inspect the MAP Sensor for proper installation.
P2173-HIGH AIRFLOW/VACUUM LEAK DETECTED (SLOW ACCUMULATION) (CONTINUED)
² When Monitored:
Ignition on and engine running with no MAP Sensor DTCs.
² Set Condition:
A large vacuum leak has been detected or both of the TP Sensors have failed based on their position being
2.5 volts and the calculated MAP value is less than the Gas Flow Adaptation value is too high. One trip fault the code will set within 5 seconds. ETC light will flash.
Possible Causes
VACUUM LEAK
RESISTANCE IN THE (F856) 5-VOLT SUPPLY CIRCUIT
(F856) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
RESISTANCE IN THE (K1) MAP SIGNAL CIRCUIT
(K1) MAP SIGNAL CIRCUIT SHORTED TO GROUND
RESISTANCE IN (K900) SENSOR GROUND CIRCUIT
RESISTANCE IN THE (F855) 5-VOLT SUPPLY CIRCUIT
(F855) 5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
RESISTANCE IN THE TP SENSOR SIGNAL CIRCUIT
TP SENSOR SIGNAL CIRCUIT SHORTED TO GROUND
RESISTANCE IN THE (K922) TP SENSOR RETURN CIRCUIT
MAP SENSOR
TP SENSOR
PCM
joey is offline
Old 11-08-2008, 03:12 PM   #3 (permalink)
I figured it out... when I was replacing the egr I must have dropped the tube seal. Now the only problem is that no one in my town has one. One thing that they told me was that I need 2. Is this correct?
Old 11-08-2008, 03:16 PM   #4 (permalink)
Member Number: 232
What is a tube seal?
joey is offline
Old 11-08-2008, 09:06 PM   #5 (permalink)
The tube seal goes on the end of the EGR tube where it hooks into the intake
Old 11-09-2008, 07:33 AM   #6 (permalink)
Member Number: 232
The Service Manual seems to imply there are more than one.
For removal it says "When removing EGR upper tube assembly being careful not to drop the silicone rubber seals in the intake manifold"
For installation it also refers to more than one.
But this online parts site only shows one tube seal, number 6.
The pic is for a 2.7L, but I think they are essentially the same.
These online parts diagrams are not always accurate, especially for seals and gaskets.
http://www.trademotion.com/partlocat...=6&catalogid=2
Replaced egr valve... Now What-egr-3.5l-removal.jpg   Replaced egr valve... Now What-egr-3.5l-install-1.jpg   Replaced egr valve... Now What-egr-3.5l-install-2.jpg
joey is offline
Old 11-09-2008, 07:54 AM   #7 (permalink)
Administrator
Points: 286,364, Level: 1 Points: 286,364, Level: 1 Points: 286,364, Level: 1
Activity: 34% Activity: 34% Activity: 34%
Rambit's Avatar
Car: 2005 300C SRT8
Member Number: 1493
Good information in here. Thanks joey!
Bernie
Click Here To Put Your Location On The 300cforums.com Member Map
Rambit is offline
Old 11-11-2008, 06:48 PM   #8 (permalink)
thanks.... got it all fixed up. You guys are great
Old 03-29-2009, 07:18 PM   #9 (permalink)
Points: 846, Level: 1 Points: 846, Level: 1 Points: 846, Level: 1
rvpimp's Avatar
Member Number: 6374
You guys are fantastic. I've had this code on my 300 since purchase. Thanks for the info, searching out an EGR as soon as possible.
rvpimp is offline
Old 10-03-2011, 02:19 PM   #10 (permalink)
Points: 2,204, Level: 1 Points: 2,204, Level: 1 Points: 2,204, Level: 1
Car: 2006 Chrysler 300c 3.5 V6
Member Number: 31314
Hi
Replaced the blue dust seal on the 3.5 V6 but still had a leak.
Called Chrysler UK who have the same diagram above and inform me that there is no black rubber seal. Looked at Haynes manual and sure enough there is the blue dust seal and the black rubber seal.
Could someone please let me have the item/product code for this seal?
Thanks!!
DATMAN is offline
HEMI EGR valve??? Steve Gee European & Diesel Powered 300 Models 18 08-27-2010 04:27 PM
Egr Valve Location? Sudesh European & Diesel Powered 300 Models 3 06-05-2010 06:58 PM
EGR Valve? J1O1H1N1F32 General Discussion 20 04-18-2010 09:11 PM
EGR Valve? wardj29_05 Problems / Dealer Service 4 11-11-2008 06:45 PM
o2 sensor and EGR valve already?!?!?!?! machosos Problems / Dealer Service 4 09-09-2008 07:41 PM
