Red Lightning music - Chrysler 300C Forum: 300C & SRT8 Forums
» Auto Insurance
Old 12-03-2008, 04:22 PM   #1 (permalink)
Points: 1,885, Level: 1 Points: 1,885, Level: 1 Points: 1,885, Level: 1
realsmooth's Avatar
Car: 2006 Chrysler 300
Member Number: 7703
Red Lightning music
my chrysler 300 wont start!! and it just shows a red lightning bolt on my dash. does anyone know the promblem?
realsmooth is offline
Old 12-03-2008, 04:45 PM   #2 (permalink)
Banned by AutoGuide
Member Number: 5683
that is the Throttle Body (drive by wire system)
the PCM is not getting a signal from it..
check the connector, I've heard of several with the problem. If the connector is seated properly, then it's possible the MAP sensor is bad (another common problem)
Mr. iNCREDIBLE is offline
Old 12-03-2008, 07:59 PM   #3 (permalink)
realsmooth's Avatar
Member Number: 7703
do you know how i can check that and where it is, im sorry im not too good with cars.
Old 12-03-2008, 08:44 PM   #4 (permalink)
Major Contributing Member
Points: 13,134, Level: 1 Points: 13,134, Level: 1 Points: 13,134, Level: 1
wog boy's Avatar
Car: . BMW 750Li on 22's
Member Number: 5242
Hi mate, when you say "don't start" do you mean that when you turn the key the engine winds over but will not start? or turn the key and nothing happens?
That lighting bolts to me just sounds like you have a flat battery??
wog boy is offline
Old 12-03-2008, 09:58 PM   #5 (permalink)
realsmooth's Avatar
Member Number: 7703
no it winds over it just dies out a sec later
Old 12-03-2008, 10:46 PM   #6 (permalink)
wog boy's Avatar
Member Number: 5242
Sounds like it is your key, try and use your spare and let us know how that goes mate
wog boy is offline
Old 12-04-2008, 12:48 AM   #7 (permalink)
realsmooth's Avatar
Member Number: 7703
my spare does the same thing wierd
Old 12-04-2008, 01:04 AM   #8 (permalink)
wog boy's Avatar
Member Number: 5242
Sorry mate I looked into a bit and Mr i was correct, the fault on your dash indicates that you have a problem with your throttle control system, quite possible that it is just a loose plug like he said, I'm going out for dinner tonight so when I get back later I will post up some pics of where to check, the Owners Manual even quotes "Might require towing to Dealer for repair" hopefully that will be a last resort for you
wog boy is offline
Old 12-04-2008, 08:07 AM   #9 (permalink)
wog boy's Avatar
Member Number: 5242
Here mate, here are a couple of checks to do on your 2.7i like Mr i recommended, First thing I recommend you do is to disconnect the neg clamp on your battery in the boot to avoid arcing your Modules incase your find a loose connection.
1st pic is the throttle pedal assy, disconnect the plug, check inside the plug to see if a pin has wriggled out then reconnect, amazing what bass can do
2nd pic is the MAP sensor, same again disconnect and check the pins
3rd pic is the throttle body, same again disconnect and check the pins, disregard the sensor on your intake pipe assy, that is only for the engine air inlet temp
Trying all of the above and failing have you done? or disconnected anything? before this happened mate.
let us know how you go
wog boy is offline
Old 12-04-2008, 01:04 PM   #10 (permalink)
realsmooth's Avatar
Member Number: 7703
thanks on that post i will check those out... but this all happend when i had a blown break light and i took it out and put a new one in and after that my car wouldnt start
Red Lightning Bolt (Moved) mako Problems / Dealer Service 25 12-09-2011 01:09 PM
Lightning Bolt at 80mph - and Stalling - Help! TopTrainer SRT8-Specific Problems/Dealer Service 14 03-06-2011 10:12 AM
Navi and cluster lightning dims with wipers on ricardo Car Audio/Alarms/UConnect/Navigation 1 08-28-2008 11:27 PM
01 Lightning vs 03 Cobra Vids Rambit Performance General Discussion 1 05-30-2006 03:01 PM
road the lightning today. michael mulligan SRT8-Specific General Discussion 15 04-15-2006 09:28 AM
