Old 05-13-2004, 03:23 PM   #1 (permalink)
Fast4Door
Fast4Door's Avatar
Member Number: 84
Send a message via AIM to Fast4Door
Help with Homelink System??
I was wondering if someone here can help me out..
I just purchased my 300C two days ago. I didn't receive my owners manual/kit someone must have swiped it from the car, so mine is on order.
Can someone please give me directions on programming the homelink system. I've got two remotes that I need to set.
Thanks,
Ron
Dallas, TX
Current Chrysler Products:
2005 Chrysler 300C - Brilliant Black
2003 Dodge Ram 3500 Cummins HO - White
Previous Chrysler Products:
2000 Jeep Grand Cherokee - Silver
2001 Plymouth Prowler - Silver
2001 Chrysler Prowler - Mulholland Edition
Fast4Door is offline
Old 05-13-2004, 03:55 PM   #2 (permalink)
LakersFan
LakersFan's Avatar
Member Number: 64
Send a message via AIM to LakersFan
WELCOME!
Here it is straight out of the book....its kinda long. Also, it say you should be outside/near whatevery your programming whether it be a gate or garage door. And to be aware that it will be opening and closing during programming
1. Press and hold the two outer Homelink buttons, and release only when the EVIC display shows "channels cleared" (after 20 seconds). DO NOT hold the buttons for longer than 30 seconds and DO NOT repeat step one to program a second and/or third hand held transmitter to the remaining two Homelink buttons.
2. Position the end of your hand held transmitter 1-3 inches away from the Homelink buttons.
3. Simultaneously press and hold both the Homelink button that you want to train and the hand held transmitter buttons. DO NOT RELEASE THE BUTTONS UNTIL STEP 4 HAS BEEN COMPLETED.
4. The EVIC display will show "channel x training" (where x is channel 1,2 or 3). Release both buttons after the EVIC display shows "Channel X trained"
NOTE: If the EVIC display show "Did Not Train" repeat steps 2-4
5. Press and hold the just trained Home link button and observe the EVIC display. If the EVIC display shows "channel x transmit" programming is complete and your device should activate when the Homelink button is pressed and released.
NOTE: To program the remaining two HomeLink buttons, begin with "Programming" step two. Do not repeat step one.
LakersFan is offline
Old 05-13-2004, 06:27 PM   #3 (permalink)
Fast4Door
Fast4Door's Avatar
Member Number: 84
Thanks!!!
Thanks for the help!
Everything is operational now!!!!
