Horn wont honk - Chrysler 300C Forum: 300C & SRT8 Forums
» Buyers Guide
Old 02-19-2009, 12:58 PM   #1 (permalink)
Points: 4,280, Level: 1 Points: 4,280, Level: 1 Points: 4,280, Level: 1
Car: 2005 chrysler 300
Member Number: 17122
Horn wont honk
so the horn on my 300 just stopped working, its not the fuse, i checked that, the horn will honk when i lock the car or press the panic button, but it wont honk when i push the steering wheel, what could this be?
lindjung is offline
Old 02-19-2009, 02:42 PM   #2 (permalink)
Points: 35,952, Level: 1 Points: 35,952, Level: 1 Points: 35,952, Level: 1
Activity: 55% Activity: 55% Activity: 55%
UK CHRYSLER 300C's Avatar
Member Number: 12398
then its gotta be the contact in the steering wheel,now I havent pulled a"C" wheel but most wheels have a large plastic ring that activates the airbag and the contacts for the horn is in that same ring that activates the airbag,could be a break in the wiring somewhere though.I hope I'm wrong though
4300k hid main lights
4300k hid fog lights
RS UV-1, 20" alloys
NEVER SAY NEVER
UK CHRYSLER 300C is offline
Old 02-19-2009, 03:32 PM   #3 (permalink)
Points: 34,530, Level: 1 Points: 34,530, Level: 1 Points: 34,530, Level: 1
Member Number: 1483
Because the horn sounds when you press the lock or panic buttons the trouble is not the horn relay, power to the relay, or power from the relay to the horns. Something is having a problem between the horn button in the steering wheel (certainly not the most sensitive to start with!) and the front control (FCM) module.
Are any of these diagnostic trouble codes in the EVIC: B2336, B2337, or B2338?
If you would like I can scan the HORN section of the service amnual and e-mail it to you. It's like (12) pages and has step-by-step instructions, including schematics and diagrams.
DESIREE is offline
Old 02-19-2009, 04:00 PM   #4 (permalink)
Elite Contributing Member
Member Number: 232
The horn is finicky. You have to press the right spot and usually with a lot of force. Try hitting different different spots with a lot of force.
joey is offline
Old 02-19-2009, 04:10 PM   #5 (permalink)
don't have evic im in a touring model.
i sent you a pm, i'd appreciate the scans.
i know its finicky but trust me , it dont work.
lindjung is offline
Old 02-19-2009, 04:33 PM   #6 (permalink)
Banned by AutoGuide
Member Number: 5683
it won't work if the ignition is turned off BTW,
also being you have a 2005 depending on your build date, you may have the problem where the steering connector is too short and the horn connection has pulled away from the connector..
there is a TSB and repair kit out there to extend the wire loom 6 inches to resolve the issue..
Mr. iNCREDIBLE is offline
Old 02-19-2009, 04:52 PM   #7 (permalink)
mines 2005 and no probs with the horn but I do have to hit it in the right spot,think its the G-spot,lol
Old 02-19-2009, 04:56 PM   #8 (permalink)
Banned by AutoGuide
Member Number: 5683
hmm maybe the H-Spot.. hit the "G" spot and she might squirt something at you...
Old 02-19-2009, 08:01 PM   #9 (permalink)
Member Number: 1483
More like the SOB spot!
DESIREE is offline
Old 02-19-2009, 08:08 PM   #10 (permalink)
Member Number: 1483
Section "8H - HORN" of the manual sent via e-mail.
While it sure would be nice to know if any trouble codes were set so as to follow the steps of the troubleshooting procedures, after reading through those procedures it looks like a test light and voltmeter are all that are used.
As the control of the horn relay appears to originate from the front control module (FCM) you might also be poking around at the wires and connectors up underneath the front power distribution center and the back of the FCM for a loose connection.
DESIREE is offline
Air bag sensor turned on, car won't honk. VIP-HatersCantStopME Problems / Dealer Service 14 04-03-2010 07:26 PM
Where is the horn? RTP SRT8 General Discussion 12 01-05-2008 03:10 PM
Horn MFoley Australia Forum 22 07-12-2007 12:42 AM
Honk Honk LeeSoFL Problems / Dealer Service 5 06-24-2007 02:12 PM
HONK HONK....or not! Chewbacca General Discussion 3 08-24-2005 02:19 PM
