Cigarette lighter fuse? - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 11 (permalink) Old 03-08-2009, 06:53 PM Thread Starter
Points: 1,545, Level: 1 Points: 1,545, Level: 1 Points: 1,545, Level: 1
Does any one know were the cigarette lighter fuse is located? Anything I plug into the lighter to charge will not work. I think the fuse is blown dont know were to find it.
EZ300C is offline
post #2 of 11 (permalink) Old 03-09-2009, 01:00 PM
Points: 1,909, Level: 1 Points: 1,909, Level: 1 Points: 1,909, Level: 1
domdutch's Avatar
Car: 2007 chrysler touring
Send a message via MSN to domdutch
I am also having the same problem, I have tryed to operate from the lighter area and its is not working nor is the lighter itself? I have looked at the fuses in the engine bay and in the trunk and none of them are blown.
domdutch is offline
post #3 of 11 (permalink) Old 03-09-2009, 01:31 PM
Points: 830, Level: 1 Points: 830, Level: 1 Points: 830, Level: 1
I have the same problem
'05 Class is offline
post #4 of 11 (permalink) Old 03-11-2009, 07:46 AM
Elite Contributing Member
Points: 41,006, Level: 1 Points: 41,006, Level: 1 Points: 41,006, Level: 1
Cool_V_300C's Avatar
Car: 2005 (now 2013) Chrysler 300C
Did you check fuse 18 in the trunk? also are you charging with the
key on or off?
You know that fuse can be relocated so that it comes on with the
key or it can be set to always on.
Mods (2005 C): Stereo only, PAC SNI, Peripheral CHYX, XM Commander, AudioControl four.1, MTX TA5604, MTX TA5601, Polk MMC6500, Polk MMC690, JL CS212R-W0 (2013 C): None..........yet
Cool_V_300C is offline
post #5 of 11 (permalink) Old 03-12-2009, 04:19 PM
Points: 1,439, Level: 1 Points: 1,439, Level: 1 Points: 1,439, Level: 1
Car: 2005 C 300
Cigarette Lighter
I couldn't get the "center console cigarette lighter" to work. After checking the fuses I discovered there was a "dime" inside the lighter blocking the contact. I put a piece of gum on the end of a pencil and removed it, lighter now works. I no longer throw my loose change into the console.
Fast300C is offline
post #6 of 11 (permalink) Old 03-12-2009, 05:48 PM
Points: 70,989, Level: 1 Points: 70,989, Level: 1 Points: 70,989, Level: 1
Now THAT should have blown something!
DESIREE is offline
post #7 of 11 (permalink) Old 03-18-2009, 11:08 PM
Points: 1,164, Level: 1 Points: 1,164, Level: 1 Points: 1,164, Level: 1
Da1Chief's Avatar
My problem is close to those noted above but not quite. My Cigarette Lighter blows fuse #18 at ramdom intervals. 4 fuses in the past year. I can't figure out what is causing the fuse to blow. The only thing it is used for is the lighter (Yes I smoke) I use the center console to attach my charger for the cell phone.
Does anyone have any idea what may be causing the problem? Any help would be appreciated
Mopar or No Car
2006 Mineral Gray Quad Cab SRT10
2006 Metalic Gray 300C SRT8
2009 Light Sand Stone 5.7L Hemi Aspen
Sandy to my friends
US Navy Retired
Da1Chief is offline
post #8 of 11 (permalink) Old 10-04-2009, 04:55 PM
Points: 8,711, Level: 1 Points: 8,711, Level: 1 Points: 8,711, Level: 1
edvinoo's Avatar
Car: 2007 Chrysler 300c
It's aprox. 1 a clock ( night time ) here and i just could not fall asleep even though i have to wake up in 4 hours to go to work.
I was up thinking about why the lighter in the center wont work.
So i logged on here since i know that there always are some answers here.
And i eventually found out that fuse #18 is generally the issue.
So i got my flaslight and went outside to check it out.
And what do i see, THERE IS NO FUSE THERE !
I while ago i left the car at the dealership when i had some trouble with the shifter.
And they said that the fuse was blown but they replaced it.
Well geuss which fuse they used ?
They took my #18 fuse and used that one instead of putting a new one in.
Aint that some sh*t.
So as soon as im off to work i'll stop by the gas station and pick a new one up and try it....
I would not have belived it if i didn't see it with my own eyes...
( By the way dont mind the spelling )
edvinoo is offline
post #9 of 11 (permalink) Old 10-04-2009, 05:14 PM
Just reinforces the term "stealership"!
DESIREE is offline
post #10 of 11 (permalink) Old 10-05-2009, 10:25 AM
Points: 381, Level: 1 Points: 381, Level: 1 Points: 381, Level: 1
Car: 2005 Crysler 300C
I am also having a similar problem. But niether of my lighter/chargers will work. Did replacing that fuse fix your lighter Desiree?
King_D_Nyce is offline
Radio & Cigarette Lighter Not Working!!! pocohantas-300touring Car Audio/Alarms/UConnect/Navigation 4 06-18-2014 08:38 PM
Cigarette Lighter & Power Port NOT WORKING! HELP! aperahia Problems / Dealer Service 20 10-12-2011 06:34 PM
cigarette lighter not working lindjung Problems / Dealer Service 15 08-09-2011 12:20 PM
Is cigarette lighter hot w/out key in ignition? Ken Lally 1st Gen SRT8-Specific General Discussion 4 01-08-2010 07:10 AM
Replace with
