help esp bas abs light on sometimes red airbag light - Chrysler 300C Forum: 300C & SRT8 Forums
post #1 of 15 (permalink) Old 07-07-2009, 01:22 AM Thread Starter
Points: 1,046, Level: 1 Points: 1,046, Level: 1 Points: 1,046, Level: 1
Car: 2006 chrysler 300
so i bought a used 300 that was smashed very minor in the front. i fixed the sheetmetal but cant figure why the yellow/orange abs bas esp lights stay on ( the ones on the cluster) also the red airbag light comes on sometimes. (the one on the cluster) The airbags were never deployed. I also have 24"rims on it. I have pulled the #11 fuse, disconnected the battery, and tried to pull codes from the evic.(no codes popped up. )Any ideas what else i can do? Thanks.
808_300_regulah is offline
post #2 of 15 (permalink) Old 07-07-2009, 03:22 AM
Points: 320, Level: 1 Points: 320, Level: 1 Points: 320, Level: 1
i have same problem???
INKLIFE is offline
post #3 of 15 (permalink) Old 07-07-2009, 12:21 PM
Points: 8,273, Level: 1 Points: 8,273, Level: 1 Points: 8,273, Level: 1
robaustin's Avatar
I don't know about the BAS WSP light but the airbag light could indicate a bad clockspring connector in the steering column. The intermittent airbag error points to this also. Try adjusting the steering wheel in and out to see if you can trigger the problem.
Magnesium Pearl
T-Rex custom grill
22Elite Console Cover & door elbow pads
Edashkit Real California Walnut Kit
BT catch can & pink thingy replacement
Hotchkis Sway Bars
Diablo Predator CAI + 91 tune
no name CAI, similar to Air Hammer
MotoRad 4127 Thermostat
BFG's 245/55/18 on Magnum rims
robaustin is offline
post #4 of 15 (permalink) Old 07-07-2009, 12:35 PM
Banned by AutoGuide
let's start at the top....
first, the ESP/ABS lights are directly related to the ABS module and the Steering Angle Sensor.
so the car had an accident.
several things need to be reset, especially if the battery was disconnected....
starting at the top, the ABS module is attached to the ABS pump at the right front of the car, inspect it for damage, it is a black box if it has a crack or even a dent, chances are the circuit board inside got damaged, get a new one.
IF it doesn't appear to be damaged, then try to reset the steering angle sensor, to do this:
start the car, and set the wheels straight
turn off the car
restart the car
turn the wheels all the way to the right
turn the wheels all the way to the left
turn the wheels all the way to the right again
center the wheels
turn off the car
restart the car
I suggest you do this in a parking lot with some room, and you DON'T turn the wheels with the car stopped, it is very hard on the steering rack, esp with 24's
put the car in drive and roll slowly (under 1mph) as you do this.
that should reset the ESP light.. if the ABS light stays on, then I suggest finding someone with a star scan or going to a dealer and pulling the codes, the ABS module may have an issue or may need to be recalibrated, and a star scan IS required for that.
the airbag light could be a bad sensor, even though you didn't pop the airbags, you could have damaged one of the front sensors in the accident.. I suggest inspecting all the wiring behind the front fascia, the sensors are on the left and right side of the actual bumper..
#3/#5 in this image:
Mr. iNCREDIBLE is offline
post #5 of 15 (permalink) Old 07-07-2009, 08:29 PM Thread Starter
Thanks very much as soon as i get my 300 back from paint ill try those solutions. Love the murdered out sig i plan to do that to match my murdered silverado.
post #6 of 15 (permalink) Old 07-08-2009, 02:04 AM
dam thanks it worked
INKLIFE is offline
post #7 of 15 (permalink) Old 07-08-2009, 11:39 AM
Banned by AutoGuide
anytime..
post #8 of 15 (permalink) Old 07-16-2009, 05:03 PM Thread Starter
so all the lights are still on, black box looks good air bag sensors and wiring look good guess i gotta go to dealer now the blinkers high beams and wipers dont work
post #9 of 15 (permalink) Old 07-16-2009, 10:24 PM
Banned by AutoGuide
your clock spring and steering control module are bad..
the SCM controls the steering angle sensor, so that explains the ESP/BAS lights.
the clockspring connects the airbag to the column wiring, so that explains the Airbag light
$200 in parts and at least 2 hours of labor.
post #10 of 15 (permalink) Old 07-16-2009, 10:51 PM Thread Starter
hawaii will probaly be 300 in parts and 3 hours labor lol
ABS/BAS/ESP light wont go off on 2007 300 Limited slyjackson General Discussion 14 09-30-2015 01:10 PM
ABS-BAS-Trac -control light yamabob Problems / Dealer Service 7 12-08-2009 05:20 PM
Esp/bas Light On Quiknen Brakes 4 12-23-2008 12:45 PM
ESP/BAS light shuman300C General Discussion 1 11-18-2006 07:54 PM
Has anyone had the esp bas light come on? Browzsrt 1st Gen SRT8-Specific General Discussion 5 11-27-2005 12:39 PM
