Go Back   Chrysler 300C Forum: 300C & SRT8 Forums > Chrysler 300 & All LX Models Forums > Problems / Dealer Service
Old 09-08-2009, 10:24 PM   #1 (permalink)
Points: 10, Level: 1 Points: 10, Level: 1 Points: 10, Level: 1
Car: 2005 Chrysler 300c
Member Number: 23717
Electrical Problems in my 300c
Hi im experiencing electrical problems with my 2005 Chrysler 300c My drivers window stoped working my memory seats my heater jus dose not even turn on i dont want to take it in to the dealer cause i already did that once an they did not know what the hell was worng with it they said when they scanned it there was to many things to list, and that i would take them ahwhile an $$$$ to find out.
My chrysler dose have (384 000 kms) i know this alot and is possibly why it is acting up but the tranny an engine runs strong like the firstday i bought it.
Anything you guys could help me with would be very greatful.
kylernelson is offline
Old 09-09-2009, 09:42 AM   #2 (permalink)
Points: 2,495, Level: 1 Points: 2,495, Level: 1 Points: 2,495, Level: 1
Car: 2006 Chrysler 300C, SRT-8
Member Number: 7075
I had the same problem. My trunk release stoppes working as well, and as you know there is no access for a key. I also started losing indicators on my dash such as the turn signals. If this is the proiblem, the dealer had to replace an electronics module in the dash +/- $800 part.
Hopefully you will find a simpler solution
mwylie is offline
Old 09-09-2009, 09:47 AM   #3 (permalink)
Points: 23, Level: 1 Points: 23, Level: 1 Points: 23, Level: 1
Car: 2009 Dodge Charger SRT8 Super Bee
Member Number: 23679
Check you wiring between the door and the car in that rubber boot. I bet you got a broken wire in there.
lainar is offline
Old 09-09-2009, 09:56 AM   #4 (permalink)
Mr. iNCREDIBLE's Avatar
Member Number: 5683
Trader Rating: (21)
maybe, but all that he is describing goes thru the Driver Door Module, (windows, memory seats, memory mirrors, etc) I would be willing to bet the Driver Dorr Module (DDM) has gone bad. I've seen it on a few cars and mine is flaky at best, sometimes it works sometimes it doesn't, when I get around to it i will swap mine..
I know for fact it is my DDM because my starscan shows it throwing a bunch of canbus communication error codes.
Mr. iNCREDIBLE is offline
Old 09-09-2009, 02:22 PM   #5 (permalink)
You could possibly be right. I only know what happened to my brother with his Jeep Grand Cherokee. Nothing on his drivers door would work at all and we replaced the module on the door and still nothing worked. we traced it too a broken wire in the rubber boot between the door and the body of his jeep. Keep in mind that if it is a broekn wire that it will show the module as being kaput too right.
lainar is offline
Old 09-09-2009, 03:34 PM   #6 (permalink)
Ok im gunna check that out ill let you know whats up with it anyways it needs to be fixed my heat dont work an winter is on its way. lol
thanks guys
Old 09-09-2009, 07:07 PM   #7 (permalink)
Member Number: 5683
Trader Rating: (21)
yup................
